4/22/2009 1:10pm - Uplink Activity Report - 55 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 4/22/2009 1:10pm - 55 changes
Uplink Comparison Range: 04/22/2009 12:42P - 04/22/2009 01:10P
Channel Additions:
212 - EARTH [MPEG2 SD] added to EchoStar11 110W TP 21 ConUS beam (NA)
212 - EARTH [MPEG4 SD] added to EchoStar8 77W TP 21 ConUS beam (NA)
298 - ONPPV [MPEG2 SD] added to EchoStar11 110W TP 16 ConUS beam (NA)
298 - ONPPV [MPEG4 SD] added to EchoStar8 77W TP 25 ConUS beam (NA)
654 - AHTV [MPEG2 SD] added to Anik F3 118.7W TP 02 ConUS beam (NA)
655 - CQTV [MPEG2 SD] added to Anik F3 118.7W TP 02 ConUS beam (NA)
664 - SZTV [MPEG2 SD] added to Anik F3 118.7W TP 02 ConUS beam (NA)
5271(13) - KVTV [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 52 (NA)(Laredo, TX-CBS)
5272(8) - KGNS [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 52 (NA)(Laredo, TX-NBC)
5273(7) - KXOF [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 52 (NA)(Laredo, TX-N/A)
5604 - KTVA [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 1 (NA)(Anchorage, AK-CBS)
5608 - KTUU [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 1 (NA)(Anchorage, AK-NBC)
5621 - KAKM [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 1 (NA)(Anchorage, AK-PBS)
Channel Removals:
579 - INTER (A) (H) removed from EchoStar3 61.5W TP 18 ConUS beam
581 - PHNIX (A) removed from EchoStar1 148W TP 11 ConUS beam
587 - ATV (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
591 - TELSD (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
593 - RTVI+ (A) removed from EchoStar3 61.5W TP 18 ConUS beam
604 - KINO (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
608 - ITVN (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
609 - TVN24 (A) (H) removed from EchoStar1 148W TP 11 ConUS beam
623 - ZGUJ (A) removed from EchoStar1 148W TP 11 ConUS beam
653 - PEACE (NA) removed from Anik F3 118.7W TP 01 ConUS beam
5990 - TEST (NA) removed from EchoStar11 110W TP 21 ConUS beam
6113 - ATV (A) (H) removed from EchoStar1 148W TP 01 ConUS beam
6114 - TELSD (A) (H) removed from EchoStar1 148W TP 25 ConUS beam
6115 - ITVN (A) (H) removed from EchoStar1 148W TP 09 ConUS beam
6116 - KINO (A) (H) removed from EchoStar1 148W TP 07 ConUS beam
6117 - ZGUJ (A) (H) removed from EchoStar1 148W TP 27 ConUS beam
6120 - PHNIX (A) (H) removed from EchoStar1 148W TP 01 ConUS beam
6123 - TVN24 (A) (H) removed from EchoStar1 148W TP 07 ConUS beam
6134 - RTVI+ (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
6135 - INTER (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
7869 - KOAM (A) (H) removed from Echostar12 61.5W TP 13 Area 8 beam(Pittsburg, KS-CBS)
8307 - WPCH (A) (H) removed from Echostar12 61.5W TP 15 Area 7 beam(Atlanta, GA-N/A)
Channel Moves:
8506 - WCHU [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 19 to EchoStar10 110W TP 31 Spotbeam 19 (NA)
14005 - KABC2 [EPG] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar7 119W TP 03 South California beam (NA)(Los Angeles, CA-ABC)
14006 - KABC3 [EPG] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar7 119W TP 03 South California beam (NA)(Los Angeles, CA-ABC)
14007 - KCET1 [EPG] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar7 119W TP 03 South California beam (NA)(Los Angeles, CA-N/A)
14008 - KMEX2 [EPG] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar7 119W TP 03 South California beam (NA)(Los Angeles, CA-UNI)
14009 - KLCS2 [EPG] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar7 119W TP 01 South California beam (NA)(Los Angeles, CA-PBS)
14010 - KLCS3 [EPG] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar7 119W TP 01 South California beam (NA)(Los Angeles, CA-PBS)
14011 - KLCS4 [EPG] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar7 119W TP 01 South California beam (NA)(Los Angeles, CA-PBS)
14012 - KXLA2 [EPG] moved from EchoStar11 110W TP 08 ConUS beam to EchoStar7 119W TP 01 South California beam (NA)(Rancho Palos Verdes, CA-N/A)
Channel Package Flag Changes:
217 - IONW [MPEG2 SD] - EchoStar11 110W TP 19 ConUS beam changed to Available (H)
5151(7) - KOAM [MPEG4 HD] - Echostar12 61.5W TP 13 Area 8 beam changed to Available (H)(Pittsburg, KS-CBS)
5250(8) - KJCT [MPEG4 HD] - Ciel-2 129W TP 06 Spotbeam 19 changed to Available (H)(Grand Junction, CO-ABC)
5251(5) - KREX [MPEG4 HD] - Ciel-2 129W TP 06 Spotbeam 19 changed to Available (H)(Grand Junction, CO-CBS)
5252(11) - KKCO [MPEG4 HD] - Ciel-2 129W TP 06 Spotbeam 19 changed to Available (H)(Grand Junction, CO-NBC)
5253(4) - KFQX [MPEG4 HD] - Ciel-2 129W TP 06 Spotbeam 19 changed to Available (H)(Grand Junction, CO-FOX)
6799(77) - HIDEF [MPEG2 SD] - EchoStar11 110W TP 02 ConUS beam changed to Available (H)
8025(30) - KPXN [MPEG2 SD] - EchoStar11 110W TP 19 ConUS beam changed to Available (H)(San Bernardino, CA-N/A)
Channel Renames:
673 - ZOOM - Anik F3 118.7W TP 23 ConUS beam renamed to MZIKA (A)
673 - ZOOM - EchoStar1 148W TP 29 ConUS beam renamed to MZIKA (A)
673 - ZOOM - EchoStar3 61.5W TP 12 ConUS beam renamed to MZIKA (A)
Channels in the system: 6420
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Thought they announced more locals than this on the Twit?
Nice to see some activity on Spotbeam 1 on 129! Anyone in AK to confirm signal on 129 TP 12?
Sweet, more Conus spaced opened up on 110, or is that just EPG data??
Digi, are all of the TEMP HD channel bit rates flat? In other words, do they all appear to be static slates? Just curious.
TRANSPONDER CHANGES
CHANGE Tp 32 ConUS CIEL-2 129w ,8PSK SR 21500 FEC 2/3
TO Tp 32 ConUS CIEL-2 129w ,QPSK SR 20000 FEC 5/6
CHANGE TID 4007 Tp 7 SPOT 1 Ciel 2 129w ,QPSK SR 20000 FEC 7/8
TO TID 4007 Tp 7 SPOT 1 Ciel 2 129w ,8PSK SR 21500 FEC 2/3
CHANGE TID 4012 Tp 12 SPOT 1 Ciel 2 129w ,8PSK SR 21500 FEC 2/3
TO TID 4012 Tp 12 SPOT 1 Ciel 2 129w ,QPSK SR 20000 FEC 5/6
CHANGE TID 4116 Tp 16 SPOT 55 Ciel 2 129w ,8PSK SR 21500 FEC 2/3
TO TID 4116 Tp 16 SPOT 55 Ciel 2 129w ,QPSK SR 20000 FEC 5/6
I'll head home at lunch and take a look. Interesting that they have NBC included since they don't currently carry that in HD! I talked to a local dealer and he said that by May 8 we'll have some national HD.
Supposed to be
attachment.php
Supposed to be
attachment.php
I don't think Fort Smith locals will be turned on any time soon. E* is playing dumb right now. I can't get FOX or CBS with my OTA set up right now so I'm not sure how long I'll be willing to wait. The DVR is great but not so great when you can't get HD locals. Sports in SD sucks.
Just EPG data.. check the channel range and channel tag.
110 TP 7 - 4 active video streams
110 TP 13 - 4 active video streams
110 TP 17 - 6 active video streams
When I say active I mean non-slate type bandwidths. HD on 110 TP 7 and 13 should look great compared to 61.5/129 national HD.
Great! Check TP 1 - 16 and let us know. Make sure they lock as spotbeam otherwise it is probably just switch "bleed".
Hmmmm, not quite Alaska...tp12=23 signal strength spotbeam.
You're only about an hour drive from Juneau and about a 2 hour ride to Anchorage right? :) :) :) (No I'm not serious...just as you were with that reading on the AK beam)
So nothing on 110 cooking.
How about
61.5, TP23, TP24, TP25, TP27, and TP32, all of which have temps (particularly TP23)
or
129, TP17, TP18, TP19, TP20, TP22, TP26, TP28, TP30, TP31, TP32, all of which have temps?
woo hoo! Grand Junction Locals lit up in HD! (too bad not all the programming is in HD, but oh well). Thank you Dish!
How about
or
WOW... give me the channel numbers to check and I can pull up the TP's for a quick check. I'll do it later after the second uplink runs today. I don't have a dedicated dish like I do on 110/129/91, so I'll have to swing the motorized over to 61.5 and pull the uplink process down for a few minutes.
Are these up links a slow process or is it fast like turning on a light switch?
Getting the channel piped into the uplink center and over to the uplink side takes a bit of work. But actually changing the tables so I our receivers know how to tune it doesn't take much.
4/21/2009 2:26am - Uplink Activity Report - 12 changes
D
4/23/2009 10:50am - Uplink Activity Report - 2 changes
