All my questions seem to be answered except possibly whether it's best to compensate for my 24.62 degree dish offset at the polar axis angle or with the dish elevation adjustment.
I was wondering what all the confusion was about.
I think this is the root.
The angle of the top of your pole is not negotiable.
It is your latitude.
The down-tilt of the dish to see the Clarke Belt is accomplished with the elevation mount on the dish, just like it is on the little H-H motors.
The problem with most dish mounts, is that they cannot go -25° to account for the 25° up-look of the dish.
On a Plumb Pole:
When set for +25° in normal operation, the dish would be vertical due to its up-look.
If you could just spin the dish 180° so the LNB was at the top, without changing any other settings, the dish would still be vertical but looking down 25°.
edit: removed erroneous reference to skew plate.
In operation, it needs to look down about 5°, so tilt the dish up toward the sky 20°.
Now it looks down 5°.
Tilt the pole back the 35° (or whatever) of your latitude (depends on where you are), and you are getting close.
I feel the above is confusing, but if you pick your way through it, perhaps you'll find a light at the end of the tunnel.
