However, one item that I do not like is how the sats are lined up in the list. I would prefer them in numerical order, but they are either random or alphabetical by sat name.
RADAR
dido ,,,,, 6 tv and 10 radio on G28
Radar,
You can make the satellite list go by location, but for the moment I cannot recall how I did it, lol. I'll let you know when I find it again. Mine list by orbital location because that other way, like you, was bugging me. And the + sign when you're scanning just means it found a new TP that wasn't already stored in the box. If you're using the latest firmware, you should be able to reorder the sats the way you want, I can't recall if it would do that on earlier versions.
EDIT: OK, here ya go : Menu+System Setup+Others >Satellite Sort=Position. That'll put you right.
Brian,
I will remember that. Thanks for the information. I have also noticed on one or two particular satellites, the channels that I have scanned in using ALL mode that showed up as encrypted will sometimes be ITC and the next time I look at them they will be encrypted again (or pay scheme). I wonder if the TP is leased by more than one company and they share rights or time share it? Or if they encrypt certain broadcasts and allow some stuff to be ITC?
Seen it quite a few times. If I remember or notice which channels and sat, I will record them for reference. They were not channels that I would normally watch, so no concern of mine. But some folks might like to know.
RADAR
Thanks Sadoun!
What does it mean if the TP appears, but does not show the [+] sign? Is that TP already in the list but was found to be INACTIVE at the time of the scan?
RADAR
Gillham,
Is there a way to rename the sats in the Fortec? If there was, I would simply remove the alpha names and replace them with the orbital position numerically, then they might line up.
Or is there an editor for the Fortec available?
RADAR
That means the TP is active, but it is already previously stored in the receiver's menu. It is not a new addition.
Yes, Fortec have a editor for the Dynamic, it's the same then the Mercury II, but you can't rename the sats. If you rename the sat with the editor it give you only a new sat.
To Rename it with the remote.
Menu>go to Utility, Ok on Edit Satellite, Ok on Edit Satellite again, now hit one of the numerical button and you can rename the sat.
Saludos
Hiebert
Limited time offer
