And my MLB EI problems continue.... | SatelliteGuys.US
sobonefnet
322
2
PA
So in addition to the current screwing D* is administering to me by not broadcasting the Phillies feeds. I am watching the San Diego feed (local channel 4 network), and the dam audio is out of sync big time..... And I am actually paying for this crap. Thanks D*
How can you tell anyway? You cannot see the announcers when they speak. The commercials are in sync at my end.
ETA: OK...just listened to the sound of the ball hit the bat and they seem to be in sync with me. Sometimes changing the channel helps with the sync issues.
Phillies / Padres are on MLB network.
I did all of that. Put it this way, MLB Network was rebroadcasting the San Diego feed. It was so bad they switched to the Phillies feed.
I am puzzled then. I have 2 HR22's and I have the same problem on both sets. What would cause this?
UPDATE: Just checked channel 725 (MLB EI) sync issue is gone. I did call tech support and they assured me it was being escalated to the broadcast team. Ha, maybe they stood behind their word. Now wonder who I talk to about getting the Phillies feeds......
You can get it for today's game on MLBNet
Not when the blow a lead in the 9th.
I cannot for the life of me, figure out how the Pads are even half as good as they are playing.
You think you got problems. I am a Red Sox fan living in VA. They are playing the Baltimore Orioles which should be considered the home team but the Red sox home feed is blacked out. But I can get the Orioles home feed. So figure that out. Oh and to top it all off if I put channel 720-1 I can see and hear the Boston feed but if I click it it goes to the channel and tells me it has been blacked out.:confused:
of course the red sox NESN feedback is blacked out for you. the orioles and nats are your mlb territory teams.
mlb mix (720 +720-1) will never have anything blacked out and when you try to go to the actual channel it will be blacked out, perfectly normal. the mets game on sun 4/19 was on cw11 in nyc,since i dont get the channel but i am in mets territory i could see the game on mix channel from fs wisconsin feed but switching to real channel caused blackout.
Hoolup Help......
D11 and MRV
