Uplink report 4/10/9 --- BET HD | Page 2 | SatelliteGuys.US
Strange Dish told me BETHD does not exit. How come dish does not know----call dish and make their CSR lines overload untill dish fix this problem and all who should get BETHD get BETHD.
I have classic 250 plus platinum hd and it is red for me also.:confused:
i get it from 129, i dont have 61.5
I got it. I have the exact same package plus 3 premiums.
They're showing The Cookout with stretch-o-vision pan and scan! Maybe Dish is doing the upconversion. No other Viacom networks stretch 4:3. VH1 HD is showed a pan and scan 4:3 upconverted pillarboxed version of Grease earlier today. If Dish is doing the upconversion, they need to undo this stretch-o-vision crap ASAP.
4/10/2009 1:45pm - Uplink Activity Report - 3 changes
SatelliteGuys.US DishNetwork Uplink Activity Report - 4/10/2009 1:45pm - 3 changes
Uplink Comparison Range: 04/09/2009 07:14P - 04/10/2009 01:45P
Channel Type Changes:
5862 - SPEC1 EchoStar1 148W TP 19 ConUS beam changed from MPEG2 SD to SD TV (NA)
Channel Renames:
9510(124) - TMP47 - Ciel-2 129W TP 19 ConUS beam renamed to BET (A)
9510(124) - TMP47 - Echostar12 61.5W TP 19 ConUS beam renamed to BET (A)
Channels in the system: 6404
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
I called Dish tech support. They sent a hit to my receivers. I get BET HD now. They said it did not update automatically because they had not sent out the final activation step, yet. So either call them or just wait a few hours.
D
4/13/2009 7:13pm - Uplink Activity Report - 1 change
D
4/14/2009 11:48am - Uplink Activity Report - 3 changes
