I have a 222 and I just got a 211k receiver. I don't see anyway to disable updates on the 211k. Is this possible? (It screws with my htpc when it shuts down every night).
Did you get an owner's manual with your 211k? If so, did you check to see if the option SCHEDULING RECEIVER UPDATES noted on page 66 is in the menu?
If you didn't get an owner's manual, you can download the pieces at: DISH Network - Support - 1.888.825.2557
Wasn't that a friendly welcome to Satellite Guys![]()
The item is in the menu and it allows me to change the time at which the updates occur. However, my 222 has an additional item on that page which allows me to disable updates completely. The 211k does not.
I was wondering the answer to this same question. I thought my 211k use to have a disable update menu item, but I cannot find it now. My unit recent reset itself after a power outage and now it updates the guide every night and then puts itself to sleep. This screws up my recordings with my HD-PVR and SageTV software. It didn't happen until the power outage.
Anyone else know if the 211k had a recent firmware update that did away with the "disable updates" option?
Thanks,
I have a Dish VIP-211k box and I would like to disable the automatic updates. I thought this use to be possible, but I do not see it in the menus anymore. I know I can customize the time that the update occurs, but there does not appear to be a way to turn the update off. Was there a recent firmware that changed this? Now my box updates itself everyday and puts itself to sleep. I don't want the box to put itself to sleep, so in the past I have disabled the automatic updates.
Thanks,
Thank you for your email. We apologize for any inconvenience this may have caused. The menu option to disable daily Updates has been removed from the models 211 and 211k. Future software releases will remove the option from all receivers that currently have it. If the receiver also turns itself off after a certain period of inactivity, you may disable this by pressing Menu on the Dish Network remote. Then select Preferences, Inactivity Standby, and adjust the settings to your liking.
Your business is greatly appreciated and we thank you for allowing us to be of assistance to you. If you have further questions you can respond to this e-mail or access our online technical support at the following link:
http://tech.dishnetwork.com/departmental_content/techportal/index.shtml
A Technical Service Representative is available via live chat 24 hours a day, 7 days per week regarding your concerns. Please click the following link to use this option.
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/techchatadvcustformrf23.shtml
Thank you,
Lucas S.
DISH Network Technical E-care
Limited time offer
