What is the MAX length of cable you can use for a V3000? I want to place the V3000 in a box mounted on the pole about 75-100' away from the reciever. Will I have any issues? I don't "think" there will be any problems but I want to be sure.
There shouldn't be any problem.The box is a NEMA enclosure. Its sealed.
I also do not think that u will face any problem. So do not worry at all.What is the MAX length of cable you can use for a V3000? I want to place the V3000 in a box mounted on the pole about 75-100' away from the reciever. Will I have any issues? I don't "think" there will be any problems but I want to be sure.
The diseqc signals should travel down the coax to the box unhindered, much like remote-mounting any small H-H motor.
The shorter wiring between the Gbox 3000 and the motor should be a benefit.
I haven't fired up my Gbox yet, so I don't know how much heat it produces in operation (or idle).
The fact that your NEMA box is sealed is a little worrisome.
If not for any heat generated, then for heating by the sun on a bright day.
I'd try locating a temperature sensor inside the box and monitoring during summer days, to assure yourself all is well.
Make sure the box is a light color, and locate it in the shade.
Whats the advantage to having the GBox outside?
I keep mine inside the house where its safe and I can monitor it. There is 130 feet of sprinkler wire from the GBox to my Dish motor and it does fine.
Brett
Now if you believe that, I have some prime Florida real estate for you............lolI had thought of the heat problem. The NEMA box is light grey in color. "If" I have a het problem I might be able to snag a supercool heat exchanger from work. We used them in these same NEMA boxes with electronic components inside and they will keep the box within a set range of temperature.
Well....one is shorter run of cable as Anole mentioned. I hadn't thought of that. That alone should make it easier on the motor control side of the V3000 because of less cable run. I just want a clean install. I'm using it as a DiSEqC 1.2 positioner not as a standalone positioner. Once the BUD is pointed and tuned there should be no need to even look at the V3000 since everything can be done remotely via the reciever.
I should pick out a box today at work. I'll post pics if I get a chance. I did look at the bottom of the G-Box. There is no way of "mounting" it. It will have to be set on a shelf.
Limited time offer
