moterized dish | SatelliteGuys.US
moterized dish
cheito
85
usa
need help i have just a little knowlege i am trying to set up a moterizing dish to get true fta channels i live in the usa i have a 36inch pansat dish with a motorized motor and an incacom lmb which i know i can get circular and linar signal need to see if anybody has like a attachment file where to go and see a set-up ?? dont know thanks.; p.s i have a pansat 2700 and a viewsat ultra recivers
i bougth this dish at www.skyviewfta.com this was app. 2 years ago i was living in an apartment complex and i couldent put this dish now i live in a house where i can install it
got a question if i have an invacom lmb i have two outlets 2 for circular and 2 for linar do i need a disequ switch and how do i hook up lmb 1,2,3,4, on the switch thanks.
thanks guys with what i have heard and read from other post threads i have an idea i think i am going to enjoy true fta thanks everyone.
Chieto,
If you want to view any of the free channels on the circular satellites, like the NASA channel, you will want to use a DiSEqC switch placed in between your motor and the Invacom LNBF.
It does not matter which port on the switch (1, 2, 3 or 4) that you use for the linear or circular connections as long as you set the installation menu selections within the reciever to match what you have hardwired.
With a typical 4X1 DiSEqC switch (the most readily available) you have four input ports, but connecting all four to the Invacom LNBF is a bit futile. You only need two ports, one for each polarity type (circular/linear).
There are not too many channels available that are in the clear (FTA) from the circular birds and other than NASA on 119, the ones that are in the clear are not usually worth watching. However, it is handy to have this option when checking your dish and motor alignments. The circular signals are easier to detect.
Radar
thanks for your reply !!! i am going to get this started soon but i heard that galaxy 10 has a lot of free channels are these channels are on circular or linar signals and what else could i capure thanks.
Galaxy 10R is now Galaxy 18 at 123W and these are linear signals.
There are many more across the arc. 30W, 43W, 63W, 72W, 74W, 79W, 83W, 87W, 89W, 91W, 93W, 95W, 97W, 99W, 101W, 103W, 105W, 113W, 116.8W, 123W, 125W and 129W all have something available that is FTA (in the clear) and linear.
Some sats like 129 only have one channel available, but it might be to your liking.
97W and 123W carry the bulk of the FTA channels.
Radar
COREAVC updated to 1.9.5
Fortec Star Dynamic Video Settings
