3/5/2009 2:35am - Uplink Activity Report - 15 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/5/2009 2:35am - 15 changes
Uplink Comparison Range: 03/05/2009 02:04A - 03/05/2009 02:35A
Channel Package Flag Changes:
5151(47) - WTEV [MPEG4 HD] - EchoStar8 77W TP 05 ConUS beam changed to Available (H)(Jacksonville, FL-CBS)
5153(30) - WAWS [MPEG4 HD] - EchoStar8 77W TP 05 ConUS beam changed to Available (H)(Jacksonville, FL-FOX)
5171(21) - WHP [MPEG4 HD] - EchoStar8 77W TP 01 ConUS beam changed to Available (H)(Harrisburg, PA-CBS)
5180(49) - KTKA [MPEG4 HD] - Echostar12 61.5W TP 05 Area 8 beam changed to Available (H)(Topeka, KS-ABC)
5182(27) - KSNT [MPEG4 HD] - Echostar12 61.5W TP 05 Area 8 beam changed to Available (H)(Topeka, KS-NBC)
5183(43) - KTMJ [MPEG4 HD] - Echostar12 61.5W TP 05 Area 8 beam changed to Available (H)(Topeka, KS-N/A)
5193(16) - KLRT [MPEG4 HD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Little Rock, AR-FOX)
7391(49) - KTKA [MPEG4 SD] - Echostar12 61.5W TP 05 Area 8 beam changed to Not Available(Topeka, KS-ABC)
7393(27) - KSNT [MPEG4 SD] - Echostar12 61.5W TP 05 Area 8 beam changed to Not Available(Topeka, KS-NBC)
7394(43) - KTMJ [MPEG4 SD] - Echostar12 61.5W TP 05 Area 8 beam changed to Not Available(Topeka, KS-N/A)
9016(21) - WHP [MPEG4 SD] - EchoStar8 77W TP 01 ConUS beam changed to Not Available(Harrisburg, PA-CBS)
9051(47) - WTEV [MPEG4 SD] - EchoStar8 77W TP 05 ConUS beam changed to Not Available(Jacksonville, FL-CBS)
9053(30) - WAWS [MPEG4 SD] - EchoStar8 77W TP 05 ConUS beam changed to Not Available(Jacksonville, FL-FOX)
9353(16) - KLRT [MPEG4 SD] - EchoStar8 77W TP 09 ConUS beam changed to Not Available(Little Rock, AR-FOX)
Channel Type Changes:
6294(21) - WHP EchoStar8 77W TP 01 ConUS beam changed from MPEG4 SD to MPEG4 HD (A) (H)(Harrisburg, PA-CBS)
Channels in the system: 6508
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
...as WHP's OTA signal on channel 4 is barely visible.
I am in the exact same boat. Wonder what they did to tick off the FCC (by giving a lightbulb powered low VHF digital frequency to a UHF network)??
I was ticked when Newport decided to tow the gov't line and wait til June to convert. In this case... dish came through, so, in a rarity for this week. Thank you dish for getting me my CBS in HD. :up ('bout time)
I was also ticked. I have an antenna in my attic and live right outside of Harrisburg, so I get 21 OTA, but it's weak enough that I get dropouts if conditions aren't perfect. I was not looking forward to dealing with that through March Madness.
I wish I could get the that much of the OTA signal. But regardless, we have it now and that is a good thing!:up
D
3/4/2009 10:20am - Uplink Activity Report - 4 changes
D
3/6/2009 4:32pm - Uplink Activity Report - 4 changes
