3/4/2009 10:20am - Uplink Activity Report - 4 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/4/2009 10:20am - 4 changes
Uplink Comparison Range: 03/04/2009 09:18A - 03/04/2009 10:20A
Channel Renames:
241 - WXIA - EchoStar7 119W TP 15 ConUS beam renamed to WNBC (A) (H)(Atlanta, GA-NBC)
243 - WGCL - EchoStar7 119W TP 15 ConUS beam renamed to WCBS (A) (H)(Atlanta, GA-CBS)
245 - WSB - EchoStar7 119W TP 15 ConUS beam renamed to WABC (A) (H)(Atlanta, GA-ABC)
247 - WAGA - EchoStar7 119W TP 15 ConUS beam renamed to WNYW (A) (H)(Atlanta, GA-FOX)
Channels in the system: 6498
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
I dont think digi rewrote it to detect locals changes like that, nor does he really need to as this will probably be one of the few (if not only) time the locals will change from on DMA to another and not move channel spaces. :)
Correct. I think it's a simple fix though. But of course it's going to be rare when it happens.
I don't have these networks, but for those that do... I hope that the switch to NYC channels improved the PQ somewhat. When I had the distants from AAD, they looked horrible and then after Dish Network compressed even more, they looked worse than regular Dish Network SD. However I dropped the services when they said it was going up in price.
Noticed the uplink is running a little later today. I suspect a list of locals are delaying things a bit...at least thats been the trend in the past.
Hope so! Looking for Colorado Springs, today.:hungry:
You will be happy:):):)
CHNG 5250 KRDO{COLORADO SPRINGS, CO} MPEG4 HD TID 4172 Tp 2 SPOT 28 Ciel 2 129w UNAVAIL HIDE HD MAP 13
TO 5250 KRDO{COLORADO SPRINGS, CO} MPEG4 HD TID 4172 Tp 2 SPOT 28 Ciel 2 129w AVAIL HIDE MAP 13
CHNG 5251 KKTV{COLORADO SPRINGS, CO} MPEG4 HD TID 4172 Tp 2 SPOT 28 Ciel 2 129w UNAVAIL HIDE HD MAP 11
TO 5251 KKTV{COLORADO SPRINGS, CO} MPEG4 HD TID 4172 Tp 2 SPOT 28 Ciel 2 129w AVAIL HIDE MAP 11
CHNG 5252 KOAA{PUEBLO, CO} MPEG4 HD TID 4172 Tp 2 SPOT 28 Ciel 2 129w UNAVAIL HIDE HD MAP 5
TO 5252 KOAA{PUEBLO, CO} MPEG4 HD TID 4172 Tp 2 SPOT 28 Ciel 2 129w AVAIL HIDE MAP 5
CHNG 5253 KXRM{COLORADO SPRINGS, CO} MPEG4 HD TID 4172 Tp 2 SPOT 28 Ciel 2 129w UNAVAIL HIDE HD MAP 21
TO 5253 KXRM{COLORADO SPRINGS, CO} MPEG4 HD TID 4172 Tp 2 SPOT 28 Ciel 2 129w AVAIL HIDE MAP 21
D
3/2/2009 11:22am - Uplink Activity Report - 3 changes
D
3/5/2009 2:35am - Uplink Activity Report - 15 changes
