HR2x / R22 (-100 Series Only) CE Release 0x02D3 (Special HR20-100 2/19) | SatelliteGuys.US
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
Systems in this CE
HR21-100 • HR22-100 • R22-100
HR20-100
Window of opportunity to download:
Thursday, February 12, 2009 11:00PM - 2:30AM ET
Friday, February 13, 2009 11:00PM - 2:30AM ET
Thursday, Feb 19 11pm-2:30am ET * HR20-100 model
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
The Contents of this CE Download: (Differences based on last National Release)
  • Items from CE:18:01 ModerateRisk
  • Items from CE:18:02 Moderate Risk
  • Items from CE:18:03 Moderate Risk
  • Items from CE:18:04 Moderate Risk
  • Items from CE:18:05 Moderate Risk
  • Items from CE:18:06 Release Candidate
  • Items from CE:18:07 Release Candidate
  • Items from CE:18:08 Release Candidate
New features
  • 01 - No new features in this release
Improved/Updated
  • 01 - Caller ID
  • 01 - Wireless Setup Enhancement
  • 01 - Minor UI Improvements
  • 02 - Video stability while playing currently downloading VOD programs
  • 02 - MediaShare: responsiveness of receiver when using MediaShare.
  • 03 - Brief "Searching for Signal" message after channel change HR23 Only
  • 03 - Trickplay bar when returning to Live TV
  • 03 - Diagnostics Report sending
  • 03 - Network Services stability
  • 03 - Progress bar during Guide acquisition
  • 03 - Responsivness when deleting shows on eSATA drives
  • 04 - Under the hood improvements
  • 05 - Tuner 2 low signal level readings HR21-100 only
  • 05 - Mediashare: Freezing when navigating pictures
  • 05 - Mediashare: Distorted audio
  • 05 - wireless configuration screen (SSID)
  • 05 - Improved playback of VOD content
  • 05 - System test no longer hangs at 90%
  • 05 - Added Guide Feed/Data Feed statistics to System Test
  • 06 - Stability
  • 06 - Under the hood improvements
  • 07 - Fix display issue in System Info and Test screen
  • 07 - Media Share: Corrected keep or delete OSD issue from last week's CE
  • 08 - Tuner 2 low signal level readings
Notes
  • 01 - None
  • 02 - When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
  • 02 - Please make sure to first attempt to tune to an OTA channel before running an OTA signal strength system test
  • 06 - This is a Release Candidate. Please test it completely!
  • 07 - This is a Release Candidate. Please test it completely!
Last post on this issue, even I'm getting tired of myself
1) I traced all my wires from box back to dish with a technician, all good!
2) Took BBC's off connected cables directly into box ( again without BBC's )
signal readings on both tuners in the high ninety's.
3) Replaced both BBC's hooked back into receiver, beautiful, still low tuner 2 readings.
I guess the port in the receiver could be going bad but neither I nor the tech are buying that.
Peace
HR21-100 with AM21
Scrolling through the guide seems to be a lot faster than most previous CE's. Scrolling through recorded programs is not as fast as the guide but seems to respond within 4 seconds at its slowest. Usually the real slowness of a CE starts to appear in about 3 days after getting the CE so I'll put it through its paces and report back. My tuner signal levels seem to match up okay.
HR21-100
DK:20090214-2549
This CE is really good. no issues yet but did send a report. :up
Forgot to show the variance between Tuner 1 and 2
My differences between TUNER 1 AND 2
101 -14
110 -23
119 -4
99c -11
103c -25
HR21 / HR22 / R22 (-100 Series Only) 2/12 & 2/13 CE Release 0x02D3
Wasn't this CE Cycle already made a National Release in 02CA/ 02CB on 2/5/08?? If so, why is this Ce Cycle being continued? Why are we doing the same Cycle as the other not -100 receivers?
I don't think it went national yet. When I reverted to the national a couple of days ago, I got 02AF. Maybe there's some confusion because they branched the -100 units off of the other ones that were doing these CE's and I think they were doing the national release a few days ago separately as well.
It's not unheard of for them to continue working on a cycle after a release. I'm guessing they realized there were some problems with one tuner getting poor readings so they kept working on it. That's probably why the -100 are seperate right now.
My HR20-100 just keeps saying "searching for new software" but never downloads anything. Thanks for any help.
I am not sure if this update is in the stream tonight. I have seen at the other site that they removed Thursday from the download days.
Same with mine... Searching for New Software (02B0) and flips through a bunch of random numbers in upper left... never gets's past that.
Guessing they decided not to do it tonight...was really hoping this issue would be fixed finally... gets old rebooting so you can tune to a channel.
Sorry guys, I didn't get any notice that Thursday night had been cancelled.
Sounds like all HR2x will be on for Friday/Saturday.
R15 / R16 CE Release 0X123C 2/13
