HR2x / R22 (-200&-700 only) CE Release 2/6 0x02D0 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
HR20-700
HR21-200 • HR21-700 • HR21Pro
HR22-200 • HR23-700
[strike]R22-100[/strike] • R22-200
Window of opportunity to download:
Friday, February 6, 2009 11:00PM - 2:30AM ET
Saturday, February 7, 2009 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
The Contents of this CE Download: (Differences based on last National Release)
Items from CE:19:01 Moderate Risk
Improved/Updated
  • 01 - Recording robustness
  • 01 - Support for more actors in programs
  • 01 - Video issues playing back 1080p content at lower resolutions.
  • 01 - Audio drops/out of synch after using trickplay and jumping to bookmarks on MPEG4 HD channels.
  • 01 - Mediashare:
    • Issues with only 1 photo in the photo playlist.
    • Incorrect duration for large audio files.
  • Other Mediashare fixes/tweaks.
  • 01 - Misc. UI fixes/tweaks
  • 01 - XM channels:
    • Loss of background image
    • No music info when exiting screensaver
Notes
  • You will lose you guide cache when going between national and this release
  • When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
  • Please make sure to first attempt to tune to an OTA channel before running an OTA signal strength system test
The -100 line for the HR2x and R22 is CANCELLED.
The -200 & -700 lines will be released.
What about the R22-100??
It still says the R22-100 in the first thread, by Jason. Why is there No update for -100 receivers?Are they not going to do CE Updates for these anymore or are they becoming not supported by directv anymore since they are the older ones.
I guess I should get a newer receiver then.
It is not uncommon that early in a CE cycle some manufacturer lines are left out. Sometimes that version of the software may not be ready, or Directv chooses to limit the test pool.
It has nothing to do with the -100 receivers in particular or their age or anything like that.
Don't read too much into it, this is not uncommon.
Sorry I missed that one Josh.
All HR2x/R22 -100 models were cancelled. Also looks like the HR22-200 was excluded based on xstation's post above, but I didn't get confirmation of that.
For anyone that has H21/H23s:
There is now an option in the Miscellanous Options setup screen (enabled by keyword search IAMANEDGECUTTER) to disable the MRV server.
This is useful if you do NOT want a H21/H23 to be able to play/access your playlist on a HR2x unit.
This download really screwed my HR20-700 up
Can't record 2 shows at same time, says 1 tuner not available
Says 0 signal strength on OTA but they come in fine
both tuners read 96% strength
how do I change back to old software, I can't have this BS
To go back to national software just follow the same procedure to download the CE only anytime that IS NOT:
Friday, 11:00PM - 2:30AM ET
and
Saturday, 11:00PM - 2:30AM ET
Business ?
H21 / H23 CE Release 2/6 0x42AE
