so is it ok to go out and measure with a pole or something the directioon the dish is setting now, then turn the motor back to 0, and manually turn the dish to the direction it was in. will that work?
Not all TPs in a Sat List are active at all times, you have to pick a known Live / Active TP for the Quality meter to light up.goes back down to 0 quality until i choose 12239 tp
Use long enough cables so the switch is under the motor.where to put the switch where it wouldnt be out in the weather,
Mechanically. Let the receiver drive the Dish using USALS, tweak signal by twisting the Motor on the pole and Dish Elevation.so u say not to fine tune with the receiver but manually?
This is all easier if the can bring a small TV and the receiver to the Dish.
yes it does help me and thank you very much, i guess i should have done better research but its what the site recommended. ive not done any blind scanning and i have ran into the manual tp entry problem and the fortec star problem. what i did do was take my tv outside and try to get signal that way. and i did get 87 quality with nimiq 91w, and i did get channels finally. i stored it too. here is my problem now, when i click goto sat position, it goes to 0 quality again. and when i click goto sat position on 89w, i think it is amc or something. it passes by the sat just a TAD BIT, but the quality is at like 50 when it does pass. which means i need to turn the dish a tad bit to the west and maybe adjust elevation just a little bit? but i mean nimiq comes in great. oh and i tried going to the sat closest EAST of nimiq and nothing came in at all
AcWxRadar
Thank you for all of your research to help out krisman. You did this with your FIRST post, even though you have been a member for a while, I just wanted to welcome you so-
Bob
If it's the Finder I'm thinking of, it's a Signal Finder, it does not tell you which sat you're on.i am almost to the point of getting a sat finder for like 15 bucks
alright i think with all your help that i have found that i have to go about 6 degrees west and a tad up on elevation to be at the top of the arc. since my longitude is 84.5 and i am pointed at 91w nimiq with excellent quality. that makes it 85w amc i think for my true south and that is going to b very hard to find isnt it? since it is linear? well let me know all of my settings on the tp and all and i will drag my tv outside again and see what i can do. i am almost to the point of getting a sat finder for like 15 bucks. it might save a lot of time. what experience do any of you guys have with them?
i can get a coolsat 6100 new for 66 dollars and shipping, is this a good deal? and a neusat for 49. which is better?
Limited time offer
