Ciel 2 Tracking | Page 25 | SatelliteGuys.US
Ciel 2 Tracking
what is the estimated time that this will be into the 129 sat spot
Well Charlie has said in the past they expected it to be in operation at 129W by the end of January. Based on reports here in the forum, it hasn't seemed like there has been a whole lot of urgency in testing the satellite, a little beaming noticed here and there and that's about all. There would be a fairly long list of things to test with the multitude of spotbeams onboard and such. There is still time to get the beast over to 129W by the end of the month if that's what the plan is. It's only 9 degrees from the test location. If it hasn't moved by this time next week, it probably won't make it by the end of the month.
One site, skyrocket.de, says that Nimiq 4 has 8 Ka transponders that are spotbeamed. I'm not sure what they are used for unless it is some sort of distribution downlink.
Provided they aren't intended for immediate use, those could have been tested in place. Since many of the Ciel-2 spotbeams need immediate use, they need tested.
The best comparison, as mentioned, would be E10, but it seems no one can remember how long to took to test that sat.
Of course the satellite needs to be fully tested before the client will be willing to take it over. It would be stupid to have only half of it tested, then take it over, then try to test the other half later by the client themselves.
So, here is a question for you. What happens to the old sat? Do they just send it off into orbit to a galaxy far, far away?
Dish is a couple of weeks behind schedule with Ciel-2, for sure. Part of that is due to the launch delay I would think, and the rest of the delay probably relates to the complexity of the task. Barring any unknown filings with the FCC reporting trouble, which I don't think has happened, this is just a slow process. (Like pouring molasses from a bottle: you can see it happening, but you want to pound on it to make it happen faster.:))
Assigning arbitrarily 2 to 4 days for transfer of current carriage from E5 to Ciel-2, we should be in pretty good shape for Feb. gain of HD early in the month if Ciel-2 reaches 129W by about 1-26-09. I'm looking for Ciel-2 movement within the next 2 days. (If not sooner.)
Today's the 20th so it'd have to start today if you want it there by the 26th and that's moving at 1.5 degrees per day which is an upbeat pace by satellite standards.
Turbo HD only packages for existing?
Using on-screen Customer Service via phone line
