OTA | SatelliteGuys.US
OTA
I have owned several of this model over the years and have installed quite a few for customers. They are great for $100 dollars.
I agree- you might only need an indoor antenna- Radio shack and many local SAT stores allow you to try and return. A 29.99 RCA indoor antenna worked for me. Picked up from my SAT dealer.
One strong suggestion. Avoid anything from Terk. They tend to sell stuff that is good looking, over priced, and under performing.
I did that right after I got my 722 a few months ago. I picked up some powered rabbit ears from RS. Worked great, but the wife said no way to the ugly looking things. I'm sure I can get away with a small indoor/outdoor type I can mount on my deck.
RCVR Sensitivity
Both my 211 and 722 rcv the OTA signal at about 20% lower than when I use the SAME CONNECTOR and plug it directly into the back of any HDTV. Stations I get solid with ~lower medium signal strength directly to the HDTV, but pick up only randomly and occassionally... just barely using the SAT OTA tuner.
Just thought I'd warn you.
A compliment for DishNet tech support
211 question
