Uplink Activity Report - 1/1/2009 1:02am - 17 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/1/2009 1:02am - 17 changes
Uplink Comparison Range: 01/01/2009 12:52A - 01/01/2009 01:02A
Channel Additions:
9589 - LTD9 [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
Channel Removals:
7319 - WQCW (A) (H) removed from EchoStar8 77W TP 08 ConUS beam(Portsmouth, OH)
Channel Moves:
7319 - WQCW [MPEG2 SD] moved from EchoStar5 129W TP 32 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)(Portsmouth, OH)
7319 - WQCW [MPEG4 SD] moved from EchoStar5 129W TP 32 ConUS beam to EchoStar3 61.5W TP 27 ConUS beam (A) (H)(Portsmouth, OH)
7391 - KTKA [MPEG2 SD] moved from EchoStar10 110W TP 31 Spotbeam 24(KS,MN,IA,OH,NE) to EchoStar11 110W TP 19 ConUS beam (A) (H)(Topeka, KS)
7391 - KTKA [MPEG4 SD] moved from Echostar12 61.5W TP 05 Area 8 beam to Echostar12 61.5W TP 23 ConUS beam (A) (H)(Topeka, KS)
7522 - KTEN [MPEG2 SD] moved from EchoStar10 110W TP 20 Spotbeam 21 to EchoStar11 110W TP 19 ConUS beam (A) (H)(Ada, OK)
7522 - KTEN [MPEG4 SD] moved from Echostar12 61.5W TP 01 Area 3 beam to EchoStar3 61.5W TP 27 ConUS beam (A) (H)(Ada, OK)
8678 - KUNP [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 44 to EchoStar7 119W TP 02 ConUS beam (A) (H)(La Grande, OR)
9201 - WHDF [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 11(AL,MS) to EchoStar11 110W TP 19 ConUS beam (A) (H)(Florence, AL)
9201 - WHDF [MPEG4 SD] moved from Echostar12 61.5W TP 11 Area 9 beam to Echostar12 61.5W TP 23 ConUS beam (A) (H)(Florence, AL)
9273 - WUFX [MPEG2 SD] moved from EchoStar10 110W TP 26 Spotbeam 11(AL,MS) to EchoStar11 110W TP 19 ConUS beam (A) (H)(Vicksburg, MS)
9273 - WUFX [MPEG4 SD] moved from Echostar12 61.5W TP 01 Area 9 beam to Echostar12 61.5W TP 23 ConUS beam (A) (H)(Vicksburg, MS)
9274 - WDBD [MPEG2 SD] moved from EchoStar10 110W TP 26 Spotbeam 11(AL,MS) to EchoStar11 110W TP 19 ConUS beam (A) (H)(Jackson, MS)
9274 - WDBD [MPEG4 SD] moved from Echostar12 61.5W TP 01 Area 9 beam to Echostar12 61.5W TP 23 ConUS beam (A) (H)(Jackson, MS)
9390 - WUPV [MPEG2 SD] moved from EchoStar10 110W TP 23 Spotbeam 05(NC,VA,SC,DC,MD) to EchoStar11 110W TP 19 ConUS beam (A) (H)(Ashland, VA)
9390 - WUPV [MPEG4 SD] moved from Echostar12 61.5W TP 01 Area 5 beam to Echostar12 61.5W TP 23 ConUS beam (A) (H)(Ashland, VA)
Channels in the system: 5952
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
While I understand that those in the markets listed above are unhappy, nevertheless I am surprised at the small number of removals, considering the predictions of vast number of channels going dark on January 1st...
D
Uplink Activity Report - 12/31/2008 12:57pm - 30 changes
D
Uplink Activity Report - 1/2/2009 5:37am - 1 change
