It is almost scary now, I hope it is just the hollidays that is keeping the TLEs from getting updated and not seeing any activity yet.
The Spaceway satellites are unique in this regard and require an enormous investment for a fraction of the capacity.Yes. Some sats (like DirecTV's Spaceway-1 and -2) have phased array antennas that can reshape their spots in orbit.
I am sorry for my ignorance, however you can not blame me for my honesty.
I do not quite understand the maps Nelson61 posted here, the basic part I understand, the different colors of the lines mean different signal strengths and different dish size needed.
*** Just being curios ***
There is a practical limit to dish size for most of us. As the antenna gets bigger, the beam becomes more focused. A 20 inch dish probably can see satellites within 3 degrees or so of its focus point. A 16 foot diameter dish would see beams within about 0.5 degrees of the focus point. TV Satellites move around in a small figure 8 (box) about 0.1 degrees on a side when on station. You can have an antenna diameter so large that the satellite will move in and out of the focus area.
Not necessarily.
If you have your lnb located exactly at the prime focus of the dish you do get a precise view of a smaller area of the sky, but all you have to do to widen that view is slightly defocus the lnb (move it in or out).
This is how the Dish and DirecTV offset dishes work, they are focused in the vertical plane but slightly defocused in the horizonal plane (dish is flattened slightly horizonally) so they see a line in the sky instead of a spot in the sky.
By adjusting the distance of the lnb to the 16 ft dish you can make it see a larger or smaller spot in the sky, with a slight compromise of signal strength.
Yes. Some sats (like DirecTV's Spaceway-1 and -2) have phased array antennas that can reshape their spots in orbit. But none of Dish's sats have that capability. The spots would still hit the US and maybe be useful, but they would not be were they were intended.
Yeah, they must be using reverse DBS for testing, so we can't see it.
And speaking of TT&C, what became of that video camera that's supposed to be on one of these EchoStar birds?
Limited time offer
