Slimline Footprint | SatelliteGuys.US
Slimline Footprint
BAF
5
South Pasadena, CA
I am scheduled for a HD upgrade next month and would lke to lay the groundwork as much as possible for the installer. I am planning for a wall mount on the side of my 2 story wooden home; I want to reinforce the studs in the mounting area. It would be helpful if someone could share with me the size of the foot for the EZAlign antenna mount along with the distance between the centers of the mounting holes. Many thanks for your help.
--BAF
--BAF
I think the size of the footing varies by the manufacturer. Isn't EZAlign just another name for the bubble level in the top of the mast?
You may well be right. I am looking for information about the Slimline Antenna mount.
Like I said, there is more than one company that makes them, and they do not have the same size foot.
If you make an area about the same size as a piece of paper that will give you enough coverage. Then you need to take into account where the monopoles will be.
Getting DTV installed What to look and look out for.
PI-21 21v Power Inserter Really Required??
