New Software Updates Discussion Thread | Page 22 | SatelliteGuys.US
Interesting - 110W spooling the L6.15 as TEST SW:
PID=08BCh
DownloadID:'DPTB'
Upgrading FW:
'L615': 'AAA1'- 'CYF1' 'FAE1'- 'FAE1' 'L040'- 'L614'
New FW:'L615'
List of BootStraps and BuildConfigs:
'1[1-8]1[A-G0-8]' 'RB[BDEGHK-NPS].'
IRD Model: ViP622
List of Serial Numbers:
[194]
'1[1-8]1[A-G0-8]' 'RJ[BCHJ-LNP-Z2-5].'
IRD Model: ViP722
[228]
Very interesting indeed. The one I posted they spooled it during the day too something they usually do for software testing only. Did somebody make a mistake and spooled to all receivers?
It was removed yesterday. They probably made a mistake and spooled it to all receivers during the day and removed it after they found out their mistake here at Satelliteguys.us. :)
Nope;) It was actually targetted to regions that are experiencing the most problems. They're monitoring the results.
S~
S~
You're correct. They spooled by region one time before. The 1 at the end indicates they did it by region.
'L615': 'ABA1'- 'CYF1' 'L040'- 'L614'
'1'
'1'
Smith might be able to get the zip codes.
yes and Missouri, mainly Saint Louis, is having a lot of problems with locals, audio dropouts, picture freezing.
Is there a way to force the software update? I live in Raleigh area and the problem is terrible with ABC programming. I have even received a replacement 622 from Dish to resolve the problem, but I don't want to install that and lose all my recordings if a software upgrade will do the trick.
No. See smith p's post above. It was only released to certain regions. If your region was not targeted, you will not get it. Once engineering evaluates the update, they will either release it to all subs or they will go back and rework the update if it is found to cause problems.
S~
S~
Ok, another question for you. If I activate the replacement 622, will it automatically load the latest software when installed?
for a 622 you'll probably get L614 which is the current default software. When/if L615 or higher is targeted for the new receivers CAID (R00), and your region, you'll get it. You can NOT force the issue. You get what Dish wants you to get.
Based on what some folks have said, yes, it includes "folders" for the EHD (based on name, like on the main HDD).
Not sure about the Seagate fix.
Ok, I installed the replacement 622. But before I did so, I had an online chat with a DISH tech and she told me not to worry...when I installed the new receiver, it would automatically load the upgraded software. I asked if she was certain. She said that in 7 years, it always has, but she has learned never to say "always". Well, the updated software (L615) DID NOT load! I haven't recorded anything yet on ABC to see if the problem has been fixed, but burns me up that she told me it would load the updated software and it didn't!
It did. L6.14 is the current valid software version. L6.15 is not in the stream for your receiver or area.
S~
The current software for 622 is L614 .
L615 was only spooled for a limited period of time to California, Missouri and Washington.
I don't require people to read the thread before posting, but I do require them to read the thread before complaining.
PS L615 will play back everything recorded with previous software versions without audio dropouts, so there is no need to hold off recording anything (such as on ABC and FOX).
Replacement 722
DirectTV dish on Dish Network system
