Uplink Activity Report - 12/4/2008 4:02am - 67 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 12/4/2008 4:02am - 67 changes
Uplink Comparison Range: 12/04/2008 03:02A - 12/04/2008 04:02A
Channel Additions:
4101 - GOLF [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
4101 - GOLF [MPEG4 HD] added to EchoStar5 129W TP 13 ConUS beam (NA)
4151 - VS. [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
4151 - VS. [MPEG4 HD] added to EchoStar5 129W TP 13 ConUS beam (NA)
5151(27) - WKYT [MPEG4 HD] added to EchoStar8 77W TP 20 ConUS beam (A) (H)(Lexington, KY)
5152(15) - WMTV [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 4 beam (A) (H)(Madison, WI)
5153(15) - KVRR [MPEG4 HD] added to Echostar12 61.5W TP 01 Area 1 beam (NA)(Fargo, ND)
5161(10) - KOLN [MPEG4 HD] added to Echostar12 61.5W TP 11 Area 8 beam (A) (H)(Lincoln, NE)
5172(7) - WITN [MPEG4 HD] added to Echostar12 61.5W TP 07 Area 5 beam (NA)(Washington, NC)
5181(13) - WIBW [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 8 beam (A) (H)(Topeka, KS)
5182(10) - WILX [MPEG4 HD] added to Echostar12 61.5W TP 07 Area 4 beam (A) (H)(Onondaga, MI)
5192(16) - WNDU [MPEG4 HD] added to Echostar12 61.5W TP 13 Area 4 beam (A) (H)(South Bend, IN)
5202(3) - WSAZ [MPEG4 HD] added to EchoStar8 77W TP 08 ConUS beam (A) (H)(Huntington, WV)
5202(6) - WOWT [MPEG4 HD] added to Echostar12 61.5W TP 11 Area 8 beam (A) (H)(Omaha, NE)
5221(10) - KWTX [MPEG4 HD] added to Echostar12 61.5W TP 11 Area 3 beam (A) (H)(Waco, TX)
9428 - TMP20 [MPEG4 HD] added to EchoStar11 110W TP 07 ConUS beam (NA)
9430 - TMP21 [MPEG4 HD] added to EchoStar11 110W TP 07 ConUS beam (NA)
9445 - TMP22 [MPEG4 HD] added to EchoStar11 110W TP 07 ConUS beam (NA)
9447 - TMP23 [MPEG4 HD] added to EchoStar11 110W TP 13 ConUS beam (NA)
9448 - TMP24 [MPEG4 HD] added to EchoStar11 110W TP 13 ConUS beam (NA)
9466 - VS. [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
9466 - VS. [MPEG4 HD] added to EchoStar5 129W TP 13 ConUS beam (NA)
9473 - GOLF [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
9473 - GOLF [MPEG4 HD] added to EchoStar5 129W TP 13 ConUS beam (NA)
9474 - TMP25 [MPEG4 HD] added to EchoStar11 110W TP 13 ConUS beam (NA)
9475 - TMP26 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
Channel Removals:
5380 - TMP15 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
5380 - TMP15 (NA) removed from EchoStar5 129W TP 03 ConUS beam
5381 - TMP16 (NA) removed from EchoStar5 129W TP 31 ConUS beam
7092 - WNDU (A) (H) removed from Echostar12 61.5W TP 13 Area 4 beam(South Bend, IN)
7282 - WMTV (A) (H) removed from Echostar12 61.5W TP 05 Area 4 beam(Madison, WI)
7317 - WSAZ (A) (H) removed from EchoStar8 77W TP 08 ConUS beam(Huntington, WV)
7392 - WIBW (A) (H) removed from Echostar12 61.5W TP 05 Area 8 beam(Topeka, KS)
7415 - KVRR (NA) removed from Echostar12 61.5W TP 01 Area 1 beam(Fargo, ND)
7512 - WILX (A) (H) removed from Echostar12 61.5W TP 07 Area 4 beam(Onondaga, MI)
7551 - KOLN (A) (H) removed from Echostar12 61.5W TP 11 Area 8 beam(Lincoln, NE)
7733 - WITN (NA) removed from Echostar12 61.5W TP 07 Area 5 beam(Washington, NC)
8986 - KWTX (A) (H) removed from Echostar12 61.5W TP 11 Area 3 beam(Waco, TX)
9142 - WOWT (A) (H) removed from Echostar12 61.5W TP 11 Area 8 beam(Omaha, NE)
9206 - WKYT (A) (H) removed from EchoStar8 77W TP 20 ConUS beam(Lexington, KY)
Channel Moves:
545 - HDPPV [MPEG4 HD] moved from EchoStar5 129W TP 13 ConUS beam to EchoStar5 129W TP 31 ConUS beam (A)
546 - HDPPV [MPEG4 HD] moved from EchoStar5 129W TP 13 ConUS beam to EchoStar5 129W TP 03 ConUS beam (A)
Channel Type Changes:
539 - HDPPV EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG4 HD (A)
4138(138) - TNT EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
4140(140) - ESPN EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
4262 - HDNET EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
4264 - HDTHR EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
4283 - HDNMV EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
5300 - ESPN EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
5333 - HDTHR EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
5350 - HDNET EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
5351 - HDNMV EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
5353 - TNT EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A) (H)
5710 - TEST EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG4 HD (A)
5903 - DRMT7 EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG4 HD (NA)
5906 - DRM10 EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG4 HD (NA)
5907 - DRM11 EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG4 HD (NA)
9420(138) - TNT EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A)
9421(364) - HDTHR EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A)
9422(362) - HDNET EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A)
9423(383) - HDNMV EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A)
9424(140) - ESPN EchoStar11 110W TP 07 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A)
9456(300) - HBO EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A)
9460(318) - SHO-E EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD ViP to MPEG4 HD (A)
9465 - MAVHD EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG4 HD (A)
9467 - HDPPV EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG4 HD (A)
9615 - BTV EchoStar11 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG4 HD (A) (H)
Channels in the system: 5826
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
MPEG2 HD to MPEG4 HD conversion complete. VS./Golf spilt warming up. Some SD to HD locals conversions live. Some National HDs(which ones?) warming up at 110:
Nice. At least 7 placeholders. And there are only 3 more Comcast networks (E!, Style, G4) so it should be more than that. And some PPV that has previously indicated may be changed to national HD, giving up 5 more possibilities.
Only thing is, those 7 need added to the EA.
And MPEG4 is nice.
Anybody had a chance to check picture quality on the new MPEG4 converted channels? Any better? No change? Worse?
Better!!
A lot cleaner picture with less noise. I have both Dish and Direct and I think the MPEG4 hd Dish are on par with Direct.
I noticed the MPEG2 hd had a slight red push in color. (I have had my set calibrated)
On the Temp channels. My guess is Viacom.
what are those drm channels?
Digital rights management
[ame="http://en.wikipedia.org/wiki/Digital_Rights_Management"]Digital rights management - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:DRM_Is_Killing_Music.svg" class="image"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/f/f0/DRM_Is_Killing_Music.svg/200px-DRM_Is_Killing_Music.svg.png"@@AMEPARAM@@commons/thumb/f/f0/DRM_Is_Killing_Music.svg/200px-DRM_Is_Killing_Music.svg.png[/ame]
7 channels per transponder for the MPEG 4 channels on TP 7 conus on 110? Is this true am I counting ESPN, TNT, HDNET, HDNETMOVIES and 4 TEMP Channels??? UGHHHHHHHHH. Directv does 4 per TP can anyone confirm?
Don't know what D* does, but 7 has been the norm on E* for some time.
D
Uplink Activity Report - 12/3/2008 12:42pm - 202 changes
D
Uplink Activity Report - 12/5/2008 12:02pm - 8 changes
