You two remember what happened to the sheriff when he went into the swamp to get Amos Moses, dontcha? Well I ain't THAT far from Thibodeaux, Louisiana.
Just sayin'.![]()
ROFLOL!
I mean a good belly laugh!!
Just sayin'.![]()
Just sayin'.![]()
You sayin you can eat up yer weight in groceries Stogie?
I miss Jerry...![]()
My Dad usta say he'd rather clothe than feed me....LOL
I listen to Jerry Reed all the time on my Zune while I am messing with the dishes....the dude could flat pick a guitar. He was VERY underrated. I was fortunate enough to see him in 2000 on the Biloxi Gulf Coast at a casino...he could still pick.![]()
Well, now I have some cleaning to do....my nephew and I put it up in about 10 minutes....I have one boss with a bolt broken off in it, and one boss with no insert at all.
I have ez-outs though, but it being like it is I don't know if I want to fool with it, if I mess up the helicoil and insert, I don't have the tools to fix that....
Man, watching yours go up is giving me the fever bad.......
I had 2 broken bolts in mine also, the 2 that are furthest to the right on the bottom, is that the same ones you are missing?
I drilled them out (no ez-outs) and was considering going oversize (1/2" instead of 3/8"), but am now leaning towards helicoils, both bosses are still in place in mine, we'll see.
Ah Stogie, you make me proud!!![]()
The "Boss" turned out to be simply a square nut on the inside that was tack welded to the backing plate. The actual pressure of the bolt holds them in place. The tack is just a holder.....
Well, since the dish is aluminum...
that washing tub welded on the back side has to be aluminum ...
So, are the nuts aluminum as well?
How else would they be tacked to the wash-tub?
(I'm obviously wrong, so please clue me in)
If I can catch up with my machinist this weekend (may see two of 'em), we'll brainstorm and see if we can come up with a repair technique worthy of the Bird.
I'm thinking about some trick with epoxy, or those internal expanding wall anchors. . .
PS: I'm also looking for good pictures and better description of how to attach a home-made magnet wheel where the pot (or old 8-magnet wheel) mounts to the opposite end of the worm, from the motor.
Still thinking about making up a few kits, if I can understand how to do it.
What a beautiful dish! I don't know much about birdviews. Is this one an 8 footer?
stogie, the anchors I was thinking about are actually for masonry/concrete. There are 2 common types, wedge and sleeve. Wedge are used more for solid concrete, sleeve are typically used in concrete block, and would be more likely to work in your application....they are much stouter than "wall anchors" (if you are talking about sheet rock anchors).
Someone told me that there is an expansion-type anchor specifically for use in metal, but I have never actually seen one.
I am also going to send some pic/measurements of my 8-magnet wheel setup to Anole, and see what he can dream up, should be interesting!![]()
Limited time offer
