Widgets Phase 2 Testing: Instructions & Issue Reports | Page 2 | SatelliteGuys.US
Not open for further replies.
A couple things, Directv isnt working on this 24/7. They probably take the weekend off. I don't know if the R22 is part of widget, we'll ask. Is anyone not having an HR2x receiver show on the website? I understand R22 are not showing, but haven't heardof any missing HR.
H series do not do widgets as far as I know, if they are showing just ignore them.
Jason here is a quote from your original post at the start of this thread.
"Widgets are only available on the HR2* and the R2* series. (They are not available on the D1*, H2*, R*, or any other DIRECTV DVR)"
My HR20-700 still doesn't show (in fact, nothing shows) in the drop-down on the widget site. No problem logging in or viewing the widget selection.
The reponse I got is that the R22 will be supported, but they still need to update some stuff for the widget site.
They weren't sure why the H receivers are showing, but are working on it.
For anyone that hasn't registered for widgets yet, please include your forum name on the registration - it makes it much easier for DirecTV to tie issues to receivers/accounts.
I must be missing something.... I'm number 802 but I can't log into the widgets site. I enter my email and password and get "your login attempt was not successful, please try again".
The Widget SDK templates DO NOT WORK!
:eek:I understand that the current Widget SDK does not work, and DirecTV is working on one that may work!
:downCannot publish: get
11:01:24,078 INFO [TemplateWidgetHandler] action requested is ##:--> updateWidget
11:01:24,078 INFO [BusinessManager] calling execute in Business Manager.. with action : updateWidget and publishing : true
11:01:24,078 INFO [BusinessManager] Taking backup of deployed_widgets.xml .
11:01:24,593 INFO [WidgetDeployer] deployed widgets count before undeploy is 1
11:01:24,968 INFO [WidgetDeployer] deployed widgets count after undeploy is 0
11:01:25,187 INFO [WidgetDeployer] deployed widgets count before deploy is 0
11:01:25,187 INFO [WidgetDeployer] parameters as below
11:01:25,390 INFO [WidgetDeployer] widget deployed successfully.
11:01:25,390 INFO [WidgetDeployer] deployed widgets count after deploy is 1
11:01:25,593 INFO [CatalogUpdater] count of deployed[1] and published[1] widgets are equal
11:01:25,593 INFO [CatalogUpdater] deployed and published widgets do not match
11:01:25,593 INFO [CatalogUpdater] publish required
11:01:25,781 INFO [CatalogUpdater] new widgetinfo created
11:01:25,843 INFO [WebServiceManager] calling updateClient Widget in webService manager, action addWidget
11:01:25,890 INFO [WidgetTransformer] Refresh Rate : 20
11:01:25,890 INFO [WebServiceManager] Adding widget images ...
11:01:25,890 INFO [WebServiceManager] webImage image file pathC:\Documents and Settings\Raymond Polone\Desktop\EighterFromDecatur.png
11:01:25,890 INFO [WebServiceManager] dockImage image file pathC:\Documents and Settings\Raymond Polone\Desktop\EighterFromDecatur.png
11:01:25,890 INFO [WebServiceManager] detailImage image file pathC:\Documents and Settings\Raymond Polone\Desktop\EighterFromDecatur.png
11:01:25,937 INFO [WebServiceManager] calling addClient athttp://widgets.directv.com/services/ClientService
11:01:35,390 ERROR [WebServiceManager] For input string: "true"
11:01:35,390 ERROR [BusinessManager] For input string: "true"
11:01:35,390 ERROR [TemplateWidgetHandler] For input string: "true"
11:01:35,390 INFO [TemplateWidgetHandler] xsl file created
11:01:35,468 INFO [AuthenticationService] before p010ne
11:01:35,468 INFO [AuthenticationService] cookie name : JSESSIONID , 1iwxlw7smshuz
11:01:35,468 INFO [AuthenticationService] after p010ne
11:01:35,468 INFO [WidgetDeployer] Getting categories..
11:01:35,468 INFO [WidgetDeployer] get the xsl from : http://192.168.1.101:5001/common-widgets/template/RSSFeed.xsl
11:01:35,468 INFO [WidgetDeployer] connection to context[/common-widgets] opened
:confused:
Solved. Not sure why, but using my user ID (not my e-mail address) works.
Yes, my HR22's are not in the list on the website.
Widgets Phase 2 Testing: General Discussion
HR2x / R22 CE Release 11/28
