But in this case, the accused devices ARE the adjudicated devices, with a modification...
Show me where "the adjudicated devices" means unmodified. This is exactly what I've been fighting.
This appears to be the first contempt case where "the adjudicated devices" ordered disabled have been modified.
No, the first question is, "does Joe Blow have a device that was ruled infringing?" If so, then its legal status has been determined.
Perhaps this is what has skipped a beat...jacmyoung said:And the same is true for all the cases we quoted, KSM, StarBrite, Footprint2.0 or Bentow Foods, in all of them, the "accused devices/products/services/processes" were "adjudicated devices/products/services/processes, with a modification."
Nice trick of English. Try this one...jacmyoung said:Because there are only two options, either "the adjudicated" or "the accused", and since you have already admitted "the accused" here is "the adjudicated with a modification", by reason of exclusion, "the adjudicated" must be unmodified. There is no other choice for you to pick.
Where does it say all modified products must follow the KSM standard? From my reading, only those accused of violating the injunction order against infringements for manufacturing, using or selling a modified device must be evaluated.Under the standard we adopt, a judgment of contempt against an enjoined party for violation of an injunction against patent infringement by the making, using or selling of a modified device may not be upheld without a finding that the modified device falls within the admitted or adjudicated scope of the claims and is, therefore, an infringement.
The KSM injunction didn't mention infringement. Neither does the disable order. The appeals court in the KSM case knew that even though infringement wasn't mentioned in the KSM order, infringement was the fundamental reason for the order and overturned the district court's contempt finding because the district court didn't look at whether there was infringement in the modified device. Likewise, if Judge Folsom finds contempt without looking at whether the modified DVRs infringe then his contempt order will be overturned for the same reason.In this case, it starts with the disable order on products already found to infringe. One cannot use a standard which applies only to the making, using or selling of an infringing product and apply it to a disable order.
...That would not apply to any other injunction order. Such as disable those found infringing...
The valid injunction violated Rule 65(d), so the Court of Appeals created this standard:Thomas22 said:The appeals court in the KSM case knew that even though infringement wasn't mentioned in the KSM order, infringement was the fundamental reason for the order and overturned the district court's contempt finding because the district court didn't look at whether there was infringement in the modified device.
The only time the KSM standard can be used is if the legal question is a "violation of an injunction against patent infringement by the making, using or selling of a modified device". Not bad for a valid injunction which violated Rule 65(d).Under the standard we adopt, a judgment of contempt against an enjoined party for violation of an injunction against patent infringement by the making, using or selling of a modified device may not be upheld without a finding that the modified device falls within the admitted or adjudicated scope of the claims and is, therefore, an infringement.
The KSM injunction didn't mention infringement but the appeals court recognized that infringement was the fundamental issue. It is the same with the disable order.The only time the KSM standard can be used is if the legal question is a "violation of an injunction against patent infringement by the making, using or selling of a modified device".
Correct. And when the charge for contempt is a violation of making, using or selling a modified device, infringement must be found on that modified device, thanks to the standard created in KSM.Thomas22 said:The KSM injunction didn't mention infringement but the appeals court recognized that infringement was the fundamental issue.
The KSM ruling talks about the judgment, not the charge. They overturned the KSM judgment and said the injunction was against infringement even though infringement wasn't mentioned in the injunction. Infringement isn't mentioned in the disable order either.Correct. And when the charge for contempt is a violation of making, using or selling a modified device, infringement must be found on that modified device, thanks to the standard created in KSM.
But when the contempt charge is not for a violation of making, using or selling a modified device, KSM doesn't apply.
The valid injunction violated Rule 65(d), so the Court of Appeals created this standard...
What? You cannot have a judgment without a charge. Courts do not operate without one party levelling a charge against another.Thomas22 said:The KSM ruling talks about the judgment, not the charge. They overturned the KSM judgment and said the injunction was against infringement even though infringement wasn't mentioned in the injunction.
Infringement is mentioned in the injunction. However, the injunction has more than one order.Thomas22 said:Infringement isn't mentioned in the disable order either.
Sure...jacmyoung said:Can you quote me where in KSM it said "the valid injunction violated Rule 65(d)"?
So...Despite the reference to the complaint, contrary to Rule 65(d), Jones has not challenged this error, nor does Jones challenge that the injunction is enforceable against devices other than the specific THERMAL-LOCK device of the original suit.
Uh, let's see if I have this right...jacmyoung said:You need to quote a case where it says violation of a "second disable order" is enough, no need to find if the modified products still infringe or not.
...The recall order is simple: the adjudicated device at distributors must be recalled. ...
...However, it is not up to TiVo to prove to Judge Folsom, or for me to prove to you, that case law exists about adjudicated products and modifications to prove contempt should be granted. ...
They were held in contempt for not recalling the products listed in the recall order of the injunction. Of course a recall order doesn't apply to products not named in the injunction as infringements:jacmyoung said:Yet Safty 1st was not in contempt for not pulling off the shelf (not obeying the secondary recall order) those adjudicated products with a modification, even though the recall order was to order SAfty 1st to pull off ALL the named products on the shelves at that time.
There is a charge for two violations of the injunction; the Court of Appeals rules on both. The one I am concentrating on is the recall order:Fisher-Price argues that Safety 1st violated the Injunction in two ways.
The recall in Safety 1st would have allowed the infringer to grab the infringing product back from distributors and modify it at the warehouse, so it could be resold. However, that recall did not extend to infringing product in customers hands, as the court ordered Safety 1st to compensate Fisher Price for infringement.Second, Fisher-Price argues that Safety 1st violated the Injunction by failing to make all reasonable efforts to retrieve infringing products from Safety 1st's major retail customers. The court agrees. Safety 1st hired another company to retrieve infringing products from Toys 'R Us and Babies 'R Us. That was a reasonable effort. But Safety 1st admits that it did not make similar efforts with its other major retail customers, such as Target. The court's order was unambiguous: Safety 1st was required to "make every reasonable effort possible." Safety 1st did not. Considering the inconsistent and delayed retrieval efforts to which Safety 1st has admitted during depositions and at trial, the court finds that Safety 1st is in contempt of the Injunction with respect to its efforts to retrieve infringing products from major retail customers.
They were held in contempt for not recalling the products listed in the recall order of the injunction. Of course a recall order doesn't apply to products not named in the injunction as infringements:There is a charge for two violations of the injunction; the Court of Appeals rules on both. The one I am concentrating on is the recall order:The recall in Safety 1st would have allowed the infringer to grab the infringing product back from distributors and modify it at the warehouse, so it could be resold. However, that recall did not extend to infringing product in customers hands, as the court ordered Safety 1st to compensate Fisher Price for infringement.
...The recall in Safety 1st would have allowed the infringer to grab the infringing product back from distributors and modify it at the warehouse, so it could be resold...
Because that isn't what happened...jacmyoung said:Again you are only quoting the part where Safty 1st was found in contempt for not pulling the products that did not have that modification, but not the part they were found not in contempt for not pulling the adjudicated products that had that modification.
And as it appears that Fisher Price did not accuse modifications of being colorably different and infringing, the KSM standard was invoked against those products...First, Fisher-Price contends that Safety 1st violated the Injunction by continuing to sell infringing models of the 2-n-1 Bouncenette and the Magic Motion after August 28, 2003. With respect to Magic Motion sales, Safety 1st has admitted to selling at least 442 units of the Magic Motion after the Injunction was entered. Safety 1st attempts to minimize its contemptuous conduct by portraying it as inadvertent or insignificant. The fact remains, however, that Safety 1st violated a valid court order. Thus, the court finds that Safety is in contempt of the Injunction with respect to Magic Motion sales. With respect to Bouncenette sales, Fisher-Price asserts that Safety 1st has failed to show that its post-Injunction Bouncenette sales were not in violation of the Injunction. Safety 1st counters that, while it sold Bouncenettes after the Injunction's entry bearing the proscribed base model numbers, all of those Bouncenettes had a new, non-infringing harness design that Fisher-Price has not accused of infringement. Safety 1st explains that it appended a revision letter to the base model numbers, rather than change the base model numbers themselves, to indicate Bouncenettes with the redesigned harness: 43002B became 43002C rather than, hypothetically, 43003. The problem is that certain of Safety 1st's sales records did not reflect the change in revision letter. This ambiguity in Safety 1st's recordkeeping appears careless in the face of the Injunction.2 Despite Safety 1st's less-than-ideal recordkeeping, however, Fisher-Price's evidence of actual contemptuous Bouncenette sales falls short of the requisite standard. The court finds that Fisher-Price has not established, by clear and convincing evidence, that Safety 1st violated the Injunction with respect to Bouncenette sales.
Limited time offer
