TV2 in the garage? | SatelliteGuys.US
TV2 in the garage?
Chavez
185
Milky Way
If I wanted to place tv2 of a 322 into my garage, about 80 feet from the receiver, could I use a diplexer and hook it to the tv2 antenna on the receiver and place the antenna in the garage off the other diplexer?
You can basically split the signal off any receiver that has a tv2 output on it. I feed 5 different locations with my tv2 output, including my garage which requires the cable run to go back outside to get to the garage.:D
make sure you change the remote address, extending your uhf ant. for tv2 makes it easier for a neighbor with the same remote address to change your channels. alot of receivers are set to default address 1.
Eastern Arc Signal Strength
DIsh HD Question(s)
