H harvis12 New Member Original poster Jun 19, 2007 3 0 Oct 31, 2008 #1 I have two seperate dtv accounts that are about 130 miles apart and how can I view opposite local channels?
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Oct 31, 2008 #2 What do you mean by opposite local channels?
H harvis12 New Member Original poster Jun 19, 2007 3 0 Oct 31, 2008 #3 receive #1`locals on #2 system
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 70,216 8,591 NW Ohio - Buckeye Country Nov 1, 2008 #4 harvis12 said: receive #1`locals on #2 system Click to expand... It depends if they are both in the same spot beam, if they are, you won't have a problem, if they are in different spot beams though, you won't get them in the other. Jimbo
jcrandall Proud Staff Member Staff member HERE TO HELP YOU! Apr 3, 2005 11,054 456 Central Michigan Nov 1, 2008 #5 If you have two accounts, the locals you receive will be based on the service address zip code for each account. You may receive different locals on each account depending on the DMA you are in. Put your zip code for each address in this site: DIRECTV - Local Channels That's all there is to it, you have no ability to choose your locals.
H harvis12 New Member Original poster Jun 19, 2007 3 0 Nov 1, 2008 #6 problem solved thanks everyone for the info and solution
