Newbie to FTA. Need help. | SatelliteGuys.US
bprm4rnt
I'm a newbie to FTA. I just got a coolstat 6000 premium from a friend. Does anyone have instructions and the necessary files to get this working.
~Thanks in advance.
Sure, and welcome to the forum!
We have plenty of help available .
Which dish 'n LNB do you have, and which satellites were you looking for?
... and if you need aiming info, what general area are you in?
City/State/Provence, or Zip code would help.
~Thanks in advance.
Welcome! I'm also playing around with the same receiver - lots of good info on the various boards here. To get you started, go to the FTA Manuals section and you can download the manual for your CS.
Note: Manual isn't real clear on what to do when you hit the "enter PIN" screen. Factory default is 0000.
Mike
LAK - if you look at the site, they no longer support the 6000.:(
Panasat 9200HD Problems
FTA and Digital OTA on the same piece of coax?
