Been thinking about doing this with my 622 box. This would remove the dvr for recording local ota channels correct?
Pick up a couple of plain ol' 2-way splitters. Connect your OTA antenna to one of the "OUT"
Now you'll be broadcasting all over the neighborhood!
Hope this helps ya.
Ed
I don't think that is correct. I have a 722 and that wasn't the case. It simply puts the OTA antenna signal to both tvs from one antenna. You can still pick up the signal on the DVR local OTA channels and record them. You just see the local channels on TV2 at their actual channel numbers (ie. 12, 7, 4, 6, etc).Been thinking about doing this with my 622 box. This would remove the dvr for recording local ota channels correct?
The only difference that I can think of is that your signal may be slightly less on the OTA antenna because it's now running through another splitter (a few db loss), but it shouldn't be enought for it to matter. Unless you were on the border of not having a good enough signal anyway.
Try it and see if it works. I'm happy (for now). And I have one less antenna for TV2 and one less coax for the kids to trip over.
Yes - it was the one that was in use when I had cable from the cable company. It's a good quality one and I'm using all RG6 coax for the connections.Did you use a standard TV splitter ?
I'm glad someone pointed this out, because I'd rather maintain one good antenna than a multiple home-made ones that aren't so hot. Plus, since I'm not subscribing to the local channels (+$5/month) it saves me $60/year.
I think I am going to have to buy a DTV converter box for TV2 if I want to keep watching the local channels on that one. But I could even record the local OTA channel on TV1 and then go to the DVR and playback on TV2 the OTA signal immediately after starting the recording.
It works the way the other guy mentioned on the 722 receiver. I don't know the difference between that and the 622.I guess I'm missing a step here.
I removed the antenna cable going into the 622 box marked Antenna and connected it to the OUT of the splitter.
I connected the cable going to my other Tv's to IN of the splitter.
622 TV -2 connected it to the OUT of the splitter.
In setup on TV1 all ota locals are 0 in signal.
I lost all my ota on TV-1 . If this hookup is correct then I'm losing signal due to the splitter.
You should have the OTA antenna going directly into the single side of a splitter and the two outputs of the splitter going to TV2 and to the receiver. Sounds like you don't have it setup that way. Just trace the path - and if the receiver and tv2 are getting a cable that is from the OTA antenna then it should work.
The splitters either combine two signals into one output, or take one input and split it between two outputs. Same splitter, just depends on what is providing the signal and what is receiving the signal. In this case one of the splitters provides output for OTA to two devices. While the other splitter provides the OTA & Satellite signal to TV2 through one coax.
Are your splitters both 2-to-1 and good quality? You shouldn't have went down to zero if things are connected right and you have good cables/splitters.
Good. I guess it was worth being 'long-winded'.Two splitters okay now it sounds better. I must of missed the 2nd splitter.
Looks like 1 have (4) total splitters behind my receiver - (2) from the original install and (2) more to make the OTA single antenna work for both tvs. Though I had the other (2) splitters already in use on tv2 - so I just moved them and rounded up a few more coax cables to make all the short connections.
Limited time offer
