I'm wondering if anyone else has noticed this. On my Visionsat 200 the Mute button only mutes the mpeg sound, not the AC3.
it makes sense that the mute feature would not work. the box is not equipped to decode the ac3 audio signal, hence there is no signal for it to mute.
Somewhere inside it's delineating the AC3 audio signal or else it would not be capable of feeding it to the two AC3 outputs, so muting it should really be quite easy.
does it pass the ac3 through the coax connection?
are you using the voom to decode the ac3 or do you have it going to a home theater?
If you mean the RF, no.
Never noticed that before, just tried it.
I used the "Extended Signal" setting for the first time yesterday (in Dish Setting Menu, press blue button), that's a great feature, it blows up the signal & quality meters up to cover half the screen, and puts out a blip tone that varies with speed/pitch as the quality level goes up or down
Great receiver!![]()
I must be missing something. My owner's manual mentions the tone feature for the signal/quality meter, but I have not been able to access it, and the "extended signal" thing with the blue button won't work either.![]()
no, i know that. i was talking about the digital coax.
Still a no-go. The only options I have in the Dish Setting screen are for the other three colored buttons. Nothing happens with the blue one there. It does the 12 screen preview thing fine though.When you have the double blue bars on the bottom, then hit the blue button.
Maybe I need an update? I'm still new at this and haven't gotten into that yet.
H/W Version S1000 1.00
Driver " API 1.00
Application " NORW v1.15
Data " FDU v1.1
Limited time offer
