It says that you can connect two external hard drives, which I happen to have. I hooked up the second drive to the front USB port and the Dish 722 does not recognize it. It does light up, but is not added to the info screen and the available MB stay the same. Does anyone know how I can get it to work
You can only use one external hard drive at a time presently. SO if you want the front external hd to work ,then uplug the back external hd and vice a versa.
I use the front USB port with my 622, so the front port does work also.Thanks for the answer, but that is what I have been boing with just one USB plug. And it looks a lot nicer without the USB cable coming out of the front of my 722. PS I tried the USB port on the front it will not recognize the external hard drive. It only works with the rear port.
Well for you D* guy's they did say the HR21 is sufficient.![]()
Limited time offer
