I see this in the CE release notes but I couldn't find any info by searching around. Is the software available yet?
I hope so too. I browsed around over there and couldn't find a link to add myself to the beta test, so I'm going to post asking how once my account is fully activated. My computer is more than capable of playing back 1080p.Thanks for the info. I've already upgraded my PC to one that can support up to 1080p and HDCP. I hope this doesn't take too long to get to market. My weak link will probably be the 802.11G wireless network.
Its a shame satguys wasnt a part of this.
I just do not see a problem with dual monitors as a serious issue at this point.Well, looking at the threads "over there" on this, it might not be the worst thing. Why?
Well, one bug that people are having a right fit over is one with dual monitors. Not only won't this app work with them, it makes you disable the non-primary monitors to make this work. Not only that, but feedback from the mods there seems to point to it possibly never changing.
I'm not so sure something like that would go over well here, to be honest. We tend to not "cleanse feedback" or ask that things be "constructive."
Not blasting the guys over there, they're simply messengers.
Then you aren't thinking about high-end Home Theater PCs that have secondary LCD displays embedded in the case.
Limited time offer
