Did it ever work with the Pansat?
If so, did you check your servo motor?
That was my thinking, but I couldn't find anything. I just heard from Pansat and they said that they haven't tested skew control for some time. They will test it today with the latest firmware to make sure it still works.Is there something on the Dish / Sat setup page that needs to be selected to activate control?
Make sure the wires from the servo go into the Pansat correctly.
Black to Grnd
Red to +5v
White to Top Hat symbol
In the Pansat satellite setup menu, there is an option for skew control. From the factory, it is set to 45 for both H and V transponders. When you push the left or right buttons on the remote and scroll through the transponders, the servo should move every time it changes from H to V or vice-versa.
If the Co-Rotor or Polarotor is not in the correct position on the dish, those skew numbers may have to be moved to +70 and -30 or further to get the transponder to tune in.
IIRC, I had to completely reverse the factory settings on the skew to get any signal on C-Band.
Hope that helps!
On mine, the Ku polarity was always in sync with the analog/4dtv, but I always had to reverse the polarity on every satellite on the C-Band side with the controls in the satellite setup screen.The 'fix' is to rotate the feedhorn 90 degrees, but then the GI 920 will be off by 90 degrees. Fortunately the 920 has a menu option for shifting the polarity of all satellites by 90 degrees.
What exactly are you doing? I can see how to change one tranponder at a time, but how do you change every transponder on a satellite in a few seconds?On mine, the Ku polarity was always in sync with the analog/4dtv, but I always had to reverse the polarity on every satellite on the C-Band side with the controls in the satellite setup screen.
That's a small price to pay than having to mess with the 4DTV. It just takes a few seconds per satellite.![]()
In the satellite setup menu screen about 4 boxes down on the individual satellite is the skew control.What exactly are you doing? I can see how to change one tranponder at a time, but how do you change every transponder on a satellite in a few seconds?
Limited time offer
