Uplink Activity Report - 7/23/2008 12:17pm - 130 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/23/2008 12:17pm - 130 changes
Uplink Comparison Range: 07/23/2008 11:51A - 07/23/2008 12:16P
Channel Additions:
626 - NHL [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (A)
627 - NHL [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (NA)
628 - NHL [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (NA)
629 - NHL [MPEG2 SD] added to EchoStar7 119W TP 13 ConUS beam (NA)
630 - NHL [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (NA)
631 - NHL [MPEG2 SD] added to EchoStar7 119W TP 18 ConUS beam (NA)
632 - NHL [MPEG2 SD] added to EchoStar7 119W TP 21 ConUS beam (NA)
633 - NHL [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (NA)
634 - NHL [MPEG2 SD] added to EchoStar7 119W TP 12 ConUS beam (NA)
635 - NHL [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (NA)
636 - NHL [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (NA)
637 - NHL [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (NA)
638 - NHL [MPEG2 SD] added to EchoStar7 119W TP 21 ConUS beam (NA)
639 - NHL [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (NA)
807 - TV9 [MPEG2 SD] added to Anik F3 118.7W TP 02 ConUS beam (NA)
4108 - LIFE [MPEG4 HD] added to EchoStar3 61.5W TP 20 ConUS beam (NA)
4108 - LIFE [MPEG4 HD] added to EchoStar5 129W TP 23 ConUS beam (NA)
4109 - LMN [MPEG4 HD] added to EchoStar3 61.5W TP 20 ConUS beam (NA)
4109 - LMN [MPEG4 HD] added to EchoStar5 129W TP 23 ConUS beam (NA)
5174(21) - WWMB [MPEG4 HD] added to Echostar12 61.5W TP 13 Area 7 beam (NA)(Florence, SC)
5343 - LIFE [MPEG4 HD] added to EchoStar3 61.5W TP 20 ConUS beam (NA)
5343 - LIFE [MPEG4 HD] added to EchoStar5 129W TP 23 ConUS beam (NA)
9540(403) - NHLN [MPEG4 HD] added to EchoStar3 61.5W TP 02 ConUS beam (A)
9540(403) - NHLN [MPEG4 HD] added to EchoStar5 129W TP 30 ConUS beam (A)
9541(113) - NHLN [MPEG4 HD] added to EchoStar3 61.5W TP 02 ConUS beam (A)
9541(113) - NHLN [MPEG4 HD] added to EchoStar5 129W TP 30 ConUS beam (A)
Channel Removals:
403 - NHLN (A) removed from EchoStar3 61.5W TP 02 ConUS beam
403 - NHLN (A) removed from EchoStar5 129W TP 30 ConUS beam
542 - NHL (A) removed from EchoStar7 119W TP 10 ConUS beam
543 - NHL (A) removed from EchoStar7 119W TP 10 ConUS beam
544 - NHL (A) removed from EchoStar8 110W TP 24 ConUS beam
545 - NHL (A) removed from EchoStar7 119W TP 13 ConUS beam
546 - NHL (A) removed from EchoStar8 110W TP 24 ConUS beam
547 - NHL (A) removed from EchoStar7 119W TP 18 ConUS beam
548 - NHL (A) removed from EchoStar7 119W TP 21 ConUS beam
549 - NHL (A) removed from EchoStar8 110W TP 24 ConUS beam
550 - NHL (A) removed from EchoStar7 119W TP 12 ConUS beam
551 - NHL (A) removed from EchoStar8 110W TP 24 ConUS beam
552 - NHL (A) removed from EchoStar8 110W TP 24 ConUS beam
553 - NHL (A) removed from EchoStar7 119W TP 10 ConUS beam
554 - NHL (A) removed from EchoStar7 119W TP 21 ConUS beam
555 - NHL (A) removed from EchoStar7 119W TP 10 ConUS beam
556 - NHL (A) removed from EchoStar7 119W TP 21 ConUS beam
557 - NHL (A) removed from EchoStar8 110W TP 24 ConUS beam
558 - NHL (A) removed from EchoStar8 110W TP 24 ConUS beam
559 - NHLN (A) removed from EchoStar3 61.5W TP 02 ConUS beam
559 - NHLN (A) removed from EchoStar5 129W TP 30 ConUS beam
5340 - ESNWS (A) (H) removed from Echostar12 61.5W TP 23 ConUS beam
5340 - ESNWS (A) (H) removed from EchoStar5 129W TP 17 ConUS beam
8697 - WMOR (NA) removed from Echostar12 61.5W TP 07 Area 2 beam(Lakeland, FL)
9400 - RSRCH (NA) removed from Echostar12 61.5W TP 21 ConUS beam
9401 - HITN (NA) removed from Echostar12 61.5W TP 21 ConUS beam
9556 - NHLHD (A) removed from EchoStar3 61.5W TP 30 ConUS beam
9556 - NHLHD (A) removed from EchoStar5 129W TP 27 ConUS beam
9557 - NHLHD (A) removed from EchoStar3 61.5W TP 30 ConUS beam
9557 - NHLHD (A) removed from EchoStar5 129W TP 08 ConUS beam
9558 - NHLHD (A) removed from EchoStar3 61.5W TP 30 ConUS beam
9558 - NHLHD (A) removed from EchoStar5 129W TP 08 ConUS beam
Channel Moves:
8700 - WFTT [MPEG4 SD] moved from Echostar12 61.5W TP 07 Area 2 beam to Echostar12 61.5W TP 01 Area 2 beam (NA)(Tampa, FL)
8703 - WXPX [MPEG4 SD] moved from Echostar12 61.5W TP 07 Area 2 beam to Echostar12 61.5W TP 03 Area 2 beam (NA)(Bradenton, FL)
Channel Package Flag Changes:
562 - NBA [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Not Available
563 - NBA [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Not Available
564 - NBA [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed to Not Available
565 - NBA [MPEG2 SD] - EchoStar7 119W TP 14 ConUS beam changed to Not Available
566 - NBA [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Not Available
567 - NBA [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Not Available
568 - NBA [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Not Available
569 - NBA [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Not Available
570 - NBA [MPEG2 SD] - EchoStar8 110W TP 16 ConUS beam changed to Not Available
571 - NBA [MPEG2 SD] - EchoStar7 119W TP 13 ConUS beam changed to Not Available
572 - NBA [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Not Available
8184(40) - WMYA [MPEG4 SD] - Echostar12 61.5W TP 01 Area 7 beam changed to Available (H)(Anderson, SC)
8185(62) - WYCW [MPEG4 SD] - Echostar12 61.5W TP 01 Area 7 beam changed to Available (H)(Asheville, NC)
8186(29) - WNTV [MPEG4 SD] - Echostar12 61.5W TP 01 Area 7 beam changed to Available (H)(Greenville, SC)
8190(33) - WUNC [MPEG4 SD] - Echostar12 61.5W TP 01 Area 7 beam changed to Available (H)(Chapel Hill, NC)
8191(32) - WNEG [MPEG4 SD] - Echostar12 61.5W TP 01 Area 7 beam changed to Available (H)(Toccoa, GA)
8192(16) - WGGS [MPEG4 SD] - Echostar12 61.5W TP 01 Area 7 beam changed to Available (H)(Greenville, SC)
9543(115) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9543(115) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Not Available
9544(116) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9544(116) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9545(117) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9545(117) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Not Available
9546(118) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9546(118) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9547(119) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9547(119) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9548(120) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9548(120) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Not Available
9549(121) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9549(121) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Not Available
9550(122) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9550(122) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9551(123) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9551(123) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9552(124) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9552(124) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Not Available
9553(125) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9553(125) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9554(126) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9554(126) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9555(127) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9555(127) - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9562(50) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9562(50) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9563(51) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9563(51) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9564(52) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9564(52) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9565(53) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9565(53) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Not Available
9566(54) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9566(54) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9567(55) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9567(55) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9568(56) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9568(56) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Not Available
9569(57) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9569(57) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9570(58) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9570(58) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9571(59) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9571(59) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
9572(60) - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Not Available
9572(60) - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Not Available
Channel Mapdown Changes:
227 - JTV EchoStar8 110W TP 03 ConUS beam mapdown of 86 added (A)
9542 - NHLHD EchoStar3 61.5W TP 30 ConUS beam mapdown changed from 30 to 114 (A)
9542 - NHLHD EchoStar5 129W TP 27 ConUS beam mapdown changed from 30 to 114 (A)
Channel Renames:
5172(32) - WFXB - Echostar12 61.5W TP 13 Area 7 beam renamed to WMBF (NA)(Myrtle Beach, SC)
5173(43) - WWMB - Echostar12 61.5W TP 13 Area 7 beam renamed to WFXB (NA)(Florence, SC)
Channels in the system: 5016
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
I wonder if WPMI in Mobile will get their stupid retrans agreement in order before the Olympics are over.
This has got to be the most pathetic large (>100 changes) uplink report in history... and I am into both the NHL and NBA! :)
this is the offseason hide the channels change. They'll be back when NBA and NHL start back up. I'm glad to get them hidden for the time being.
Dish big 8/1/08 splurge.
What will happen after 8/1 no more splurges??
No more need to look forward to the uplink report??
Will Hd be a pig in a poke??
and when will NA become A??
I do not even know why I posted this??
Oh Well
Does anyone have a clue why they would have to change the names of two of the Florence & Myrtle Beach locals? What, did they mess up and put the wrong channel names on them or something?
D
Uplink Activity Report - 8/7/2008 5:02pm - 1 change
D
Uplink Activity Report - 7/31/2008 12:02pm - 20 changes
