KNLB Changing Transponders? | SatelliteGuys.US
Cemguy
102
KNLB Radio has been broadcasting announcements that they'll be changing transponders in the Glorystar network.
Any word on what the new specs will be?
Cemguy,
This is a little off topic, but you say Central PA is the weakest section of the satellite footprint, as we are planning to get a Glorystar system in the future, do you know how the JCTV signal comes in? We are in Roxbury PA, norther Franklin County... so South Central, PA
Thanks,
Bruce - Roxtreme
Same here...Central PA is in the weakest section of the satellite "footprint". Too bad they're going with the weaker transponder.
Cemguy,
Thanks,
Bruce - Roxtreme
Today I'm getting 40% to 50% signal quality on JCTV. In other parts of the country, with the same basic GloryStar setup, people could be getting 60% - 70%.
I have no problems with reception until it rains really hard.
Thanks for the info... it's good to know. We will probably never watch anything live, so I doubt that it will be that big of a deal if a major rain storm once in a while wipes out reception of a program that we will probably be only warehousing for the future.
Thanks,
Bruce - Roxtreme
I would think that if a person purchased the 1.2 meter dish from Glorystar instead of the 92 CM dish that would help with the signal strength. Although it $69 more plus another $50 or so in shipping, it might be worth getting stronger signal.
also each receiver model has a different signal quality structure. On the same channel using 4 different boxes I can see quality readings of 70,60,55,and 90 :)
Interesting. Does that mean that the box that reads 90 is actually doing a better job of rendering the signal, or does it mean that the box just assigns a "90" to the same signal quality at which one of the boxes assigns a "55"?
its just the way the box reads it...nothing more nothing less
I know the Merc II had a software upgrade (the non glorystar model) and the meter went down drastically...what was 90 is now 60...Glorystar said that was normal
I have noticed differences between receivers so far as receiving weaker signals, even though, as you say, sometimes they just give a different reading but perform the same.
I recently tried to receive the PBS channels on AMC3, and they are quite weak (at least where I live...just north of the border above Idaho). My Coolsat 6000 would sometimes show the breakup (square boxes, picture freeze), whereas on a newer VisionSat IV200 the same signal would show a good picture without any breakup. At other sites, I noticed that the Coolsat was better at picking up weaker channels than some older receivers, such as the SatCruiser.
So it's not just a matter of different reading...some boxes actually seem to be more efficient at dealing with weaker signals.
FedEx Tracking Problem
USB 2.0 Media Recommendations
