Uplink Activity Report - 7/15/2008 4:02am - 70 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/15/2008 4:02am - 70 changes
Uplink Comparison Range: 07/15/2008 03:02A - 07/15/2008 04:02A
Channel Moves:
5631 - KATN1 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(Fairbanks, AK)
5632 - KATN2 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (NA)(Fairbanks, AK)
5639 - KTVF1 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (NA)(Fairbanks, AK)
5643 - KFXF1 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(Fairbanks, AK)
5646 - KUAC [MPEG4 HD] moved from EchoStar2 148W TP 22 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(Fairbanks, AK)
5647 - KUAC2 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(Fairbanks, AK)
5651 - KJNP1 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(North Pole, AK)
5688 - KJUD1 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(Juneau, AK)
5689 - KJUD2 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(Juneau, AK)
5704 - KTOO1 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(Juneau, AK)
5705 - KTOO2 [MPEG4 SD] moved from EchoStar2 148W TP 14 ConUS beam to EchoStar1 148W TP 13 ConUS beam (A) (H)(Juneau, AK)
5750 - DEMO1 [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5751 - VODTS [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5752 - OTST6 [134] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5754 - OTST1 [134] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5757 - TVGT [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5761 - WINK2 [MPEG2 SD] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)(Fort Myers, FL)
5762 - OTEST [134] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5763 - OTST3 [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5764 - PJAMT [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5765 - OTST2 [134] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5769 - DATST [128] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A)
5848 - SPECV [SD TV] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (NA)
5855 - ETC2 [SD TV] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
5862 - SPEC1 [SD TV] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (NA)
5863 - SPEC2 [SD TV] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (NA)
5864 - SPEC3 [SD TV] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (NA)
7644 - KDRV [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(Medford, OR)
7645 - KTVL [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(Medford, OR)
7646 - KOBI [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(Medford, OR)
7647 - KMVU [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(Medford, OR)
7648 - KFBI [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)
7650 - KSYS [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(Medford, OR)
7651 - KBLN [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(Grants Pass, OR)
7938 - KAMC [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Lubbock, TX)
7939 - KLBK [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Lubbock, TX)
7940 - KCBD [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Lubbock, TX)
7941 - KJTV [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Lubbock, TX)
7942 - KLCW [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Wolfforth, TX)
7943 - KTXT [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Lubbock, TX)
7944 - KPTB [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Lubbock, TX)
7945 - KMYL [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Lubbock, TX)
7978 - KOTA [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Rapid City, SD)
7979 - KCLO [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Rapid City, SD)
7980 - KNBN [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Rapid City, SD)
7981 - KEVN [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Rapid City, SD)
7984 - KBHE [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Rapid City, SD)
7991 - KTXE [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)
7992 - KLST [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(San Angelo, TX)
7993 - KSAN [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(San Angelo, TX)
7994 - KIDY [MPEG2 SD] moved from EchoStar2 148W TP 12 ConUS beam to EchoStar1 148W TP 15 ConUS beam (A) (H)(San Angelo, TX)
8171 - KTXS [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Sweetwater, TX)
8172 - KTAB [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Abilene, TX)
8173 - KRBC [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Abilene, TX)
8174 - KXVA [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Abilene, TX)
8177 - KIDZ [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Abilene, TX)
8178 - KPCB [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)(Snyder, TX)
8179 - KTES [MPEG2 SD] moved from EchoStar2 148W TP 16 ConUS beam to EchoStar1 148W TP 31 ConUS beam (A) (H)
9340 - KSVI [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Billings, MT)
9341 - KTVQ [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Billings, MT)
9342 - KULR [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Billings, MT)
9343 - KHMT [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 23 ConUS beam (A) (H)(Hardin, MT)
9345 - K20HB [MPEG2 SD] moved from EchoStar2 148W TP 18 ConUS beam to EchoStar1 148W TP 23 ConUS beam (NA)
19079 - OTST8 [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A)
19096 - DGAMS [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
19112 - DISAP [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A)
19128 - ICM [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A) (H)
19209 - ITV2 [DATA] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (NA)
31500 - KFUG [144] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A)
31510 - DLSV [136] moved from EchoStar1 148W TP 23 ConUS beam to EchoStar1 148W TP 19 ConUS beam (A)
Channels in the system: 5085
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
TRANSPONDER CHANGES
DELETE Tp 12 EchoStar 2 148w ,QPSK SR 20000 FEC 5/6
CHANGE Tp 13 EchoStar 1 148w ,QPSK SR 20000 FEC 5/6
TO Tp 13 EchoStar 1 148w ,8PSK SR 21500 FEC 2/3
DELETE Tp 16 EchoStar 2 148w ,QPSK SR 20000 FEC 5/6
DELETE Tp 18 EchoStar 2 148w ,QPSK SR 20000 FEC 5/6
DELETE Tp 22 EchoStar 2 148w ,8PSK SR 21500 FEC 2/3
CHANGE Tp 31 EchoStar 1 148w ,8PSK SR 21500 FEC 2/3
TO Tp 31 EchoStar 1 148w ,QPSK SR 20000 FEC 5/6
The Broadlogic Spectrum Analyzer shows no signals on the horizontal side at 148 degrees West at this time. This seems premature for the move to 77 degrees West. Echostar's FCC request for the move didn't start until September 5, 2008. I don't believe this request has been approved yet by the FCC.
Hmmm...users were reporting issues with some locals on 148 last night. I wonder if something died. That's going to put a kink into some plans. Of course this is all speculation. They could possibly be testing to see if Echo1 can do the job by itself but there are other pieces that do not add up.
Re: 129
There have been quite a few posts from all around the country with loss of signal from the 129. Perhaps DISH is beginning to see the dark at the end of the tunnel. Where is Charlie going to put all the HD? if 129 turns off, or falls in someone's back yard.
The FCC would not be happy if E5 were to run out of fuel and not be able to make it to a parking orbit.
D
Uplink Activity Report - 7/12/2008 6:02am - 2 changes
D
Uplink Activity Report - 7/16/2008 1:18pm - 28 changes
