Question about NASA and Angel ONE | SatelliteGuys.US
chapelrun
965
14
Berryville, VA
My setup gets both NASA and Angel ONE from 119W.
Just wondering way a blind scan finds each twice? Does DISH really have each channel twice on 119W or is one MPEG2 and another MPEG4. Both are viewable on my VisionSat IV-200
NASA
11868(V) 19995
10870(V) 19992
Angel ONE
11016(V) 19975
12014(V) 19978
It was your receiver's software bug; no MPEG-4 for those channels and if you look at those numbers you'll see a difference in a range of LOF standard deviation +/- 2...3 MHz.
Plus your LOF is incorrect, set it to 11250 MHz. Check Lyngsat site.
OK - I understand
Thanks guys
You're right when I got to 119W I just took the defaults in the receiver
NASA should be 12370R TP11
Angel ONE should be 12516R TP12 according to LyngSat
I feel kinda stupid though - I rescanned with the correct setup and of course then the receiver found the correct Freqs.
lost need help with the t-55
Hi I'm New Here and need some help
