Can't find how to reset. | SatelliteGuys.US
pwherr
35
Southern Colorado
I need to know the remote commands to do a master reset on a 301.Not the unplug BS the 6,1,1 left,right or whatever it is to really reset the receiver.Thanks in advance.
He must be thinking of D*. On D* receivers you can reset using the remote.
You can do it with all receivers I believe.I don't know if the sequence is the same on the newer ones or not.You push 6-1-1 then left-right-info or something.I have done it before.It dumps everything passwords and all.
I know what the op is thinking about and sorry it don't kill passwords....The only way to do that is to call dish and have then send a password re-set.
Menu- option 6(system setup)-Option 3 (Diagnostics). Press Info - Browse (Left) then themes (Right). Then press TV/Video. Then try pressing (play, play then recall). Then unplug the receiver for a few seconds then plug it back in and re-do the check switch and all of you settings that you want set up. It works on my VIP622. Not sure all the reset features on the 301 receivers.
Thanks.That gets me to the Memory Dump & Device status on the 301.
Sound
ERROR 002 on lots of channels
