euronews sat 118 | SatelliteGuys.US
euronews sat 118
skihoodoo
SatelliteGuys Guru
148
10
PERSHING COUNTY NV
i just had my new dish installed yesterday and i was wondering if anyone else occasional sees problems with this channel 784,900,901 any other channels that i get on this sat i dont have a problem with.
is anyone with the 118 sat seeing the picture being black and white with occasionale bursts of color ch 900/901
not tv becayse no other channel is doing it
edit now it is working fine
I've had the same problems with Euronews on all three channels.
It comes and goes. I'm sure it's a Euronews problem as it only happens on those channels.
Odd at times the picture will be nearly black & white with a tiny bit of color.
Or distorted at other times.
No regularity to this occuring.
Like the channel but it repeats way to many times per hour the same stories.
And the weather map goes so quick it's hard to catch the weather.
Still it's nice to see news from Europe.
Wish DISH would get the BBC World News and also EuroSport channel.
bjf
If you seen that signal level screen the you seen yellow blinking bar with a warnings about new scale.
No problem on all three Euro News channels here with D1000+ dish.
Signal strength is good - you don't have to worry about dish/switch/cabling.
Time to check your DVR statistics - post pictures of all screens selecting "Counters" in Diag menu.
screen shots
here are my screen shots
OK, we see some data to dig down on picture#3: 13) 11:42.
Now lets make pictures of Details screen(s) after press two times on SysInfo button, just give it a couple minutes to finish check signals and parse history tables.
"choppy" ViP 222
momentary freeze
