Hail storm damaged new dish | SatelliteGuys.US
PKII
791
19
WV
On Sunday we had the worst hail storm I have ever seen in my 41 years on this planet. After it was done it looked like we had 2 inches of snow on the ground but it was hail stones.
Along with a lot of other things my brand new Fortec 6 foot dish has about 10 golf ball sized dents in it. Will this affect the signal majorly? :(
I have heard that it does affect signal. How much I don't know. Iceberg has a bent dish that fell off his table out on his deck that still works (it looks pretty bad).
I would say that if you see any degraded signal it would be mostly on ku band.
I would just take some signal readings and see if they are where you were before.
If its aluminum mesh the smaller dents can be pushed out from behind.
carve a chunk of wood for the inside the same a dish curvature to hold on the inside at same time your pushing up.
This will require 2 people.
Large dents can be removed by heating with a heat gun and dollying and quickly applying a wet rag on it while still pushing.
Keep in mind the metal has been stretched
You might also try getting a 5" Rubber Sanding Block from your local auto store, there used for body work, it's flat on the bottom and curved for your hand and the one I have is made out of heavy rubber, cost about $7.00. That's what I've used to removed damage from the dish that I have up.
Thats the problem I haven't found Ku yet. I gonna have trouble when I start looking. :( C band don't look no different.
Its a steel dish.
Ok Thanks I will try that. :)
Sorry for your problem with the hail. What sort of deductable do you have on your house insurance? Perhaps they'll buy you a new dish?
Yet another reason to reuse old Primestar dishes!
You could bounce baseballs off them, and still not dent them!
We had a lot of other damage too insurance person suppose to come today. I hope it pays a lot. We have a $500 deductable however the house roof was damaged a long with the garage so. Maybe enough to cover a new dish. :)
Humm...we need the entire roof shingles replaced of house and garage. He is outside figuring the amount right now. :D .....humm.... got enough for a new 12 foot dish. ;)
hmm. dents must have helped. :D Just found Ku band signals for the first time. :)
Inexpensive dual c-band lnbf
Smallest C band dish?
