I noticed this as well - it is a great addition, however after I changed my display of recorded events to a 'flat view' (not sorted into folders), the folder for my external drive went away AND there were no listings for any of the programming on the external drive in my list.I got new software today. Not sure of the number, but I get a Folder for my External Hard Drive at the top of my Dvr Recordings directory. It's kind of nice instead of Going to USB Storage, etc.
Double press of Menu button will tell you what version it have.I got new software today. Not sure of the number, but I get a Folder for my External Hard Drive at the top of my Dvr Recordings directory. It's kind of nice instead of Going to USB Storage, etc.
L5.10 here on my 622 as well. Have noticed a few things (channels change a tad faster, except to 2-digit locals, which is the same as it's always been). the USB folder. Not anything else that's popping out at me at the moment...
Add Enable/Disable Screen for 908 Popup and Mode Reminder Screen Text Update
Have you seen anything to disable this popup? I think this is the one that pops up when you press TV on the remote control.
The only downside is the inability to hide 'questionable' programming from the wife.![]()
When a program is still on the DVR, go into the program's menu and select "Edit Name".
Change "Hot Bikini Babes" to "Economics 204".
Note that you can't "Edit Name" after it is transferred to external hard drive...
Ok,
As with one of the previous software versions (I forget which one), my local HD channels completely break up and freeze when recorded. I watch it live and it is fine, but when I play back the recording, see previous.
S~
I just posted on this and you confirmed again what I was blaming on the update but didn't want to flat out say the update did it
Yet it appears it did!
Thanks and hopefully this is fixed soon. Celtics vs Lakers took forever to happen again, lol
Ok,
S~
Limited time offer
