Having a problem with LNB Drift -7 now showing on 61.5/110/119 picture drop outs etc. Is this a service call that Dish covers or will I be responsible?
They will replace both, the 110/119 and the 61.5 for no charge? And this is the LNB's and not the dish moving? These are oriiginal LNB's 9 years old.
If the drift is 7 on all sat. the problem may not be the LNBF. If there is a poor conection or the linequality is poor it is possible to get the same drift that you have. A service tech will have to check all connections as well as the lnbf.
Yep. They will replace any failing part. And, "drift" has noting to do with the dish physically moving. It has to do with a component in the LNBF malfunctioning and causing the frequencies to "collide" thus causing the receiver to lose it's lock.
I just spent an half hour arguing tech support over drift and the need to replace the lnb on 61.5 dish. The drift was only showing up at -6, however ever since they have moved more channels to 61.5 I have been experiencing signal loss and pixation. I basically had to threaten to cancel dish and go to directv before they even wanted to send someone out to look at the problem, even though I have the dish home protection package. Then they brought up the subject of a $29 service call, which I reminded them to waive, whereas directv and/or time warner would do an installation for free.
It is really sad, when you have been a sub for five years and never had a service call and then you have to fight with tech support to fix a problem, after being left on hold for 20 minutes while being reminded by their recording of what a most valued customer I am.![]()
How you can get it ? Is there hidden screen with the numbers ?It goes up higher when it is hot outside... so call when you can read the numbers off... or just fudge the numbers and tell them the high number when you call.
7.0 is the number they are worried about... the other numbers are Serial Number, Manufacturer, and LNB Type.
yes you are responsible..to call dish and set up a service call..that's the extent of your responsibility.Having a problem with LNB Drift -7 now showing on 61.5/110/119 picture drop outs etc. Is this a service call that Dish covers or will I be responsible?
me too. sick of these trouble calls.If I go to a service call with ANY drift showing I replace the LNBFs no matter what the other problems are. I don't want a freaking 12 or 30 day TC.
Limited time offer
