HR20-700 CE Release 5/23 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE / Version
HR20-700 {CE:14:05} 0x023D
Window of opportunity to download:
Friday, May 23, 2008 11:00PM - 2:30AM ET
Saturday, May 24, 2008 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! CE DOWNLOAD WARNINGS / AGREEMENT
PLEASE READ THIS SECOND! CE DOWNLOAD INSTRUCTIONS
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the DBSTalk CE Chat on Friday nights:
chat.dbstalk.com
The Contents of the Release:
Differences based on last National Release
  • Items from CE:14:01
  • Items from CE:14:02
  • Items from CE:14:03 - High Risk Release
  • Items from CE:14:04 - High Risk Release
  • Items from CE:14:05 - High Risk Release
Improved
  • 01 - Stability
  • 01 - Accurate network connection status after reboot
  • 01 - Overall Media Share
  • 01 - Channel change speed
  • 01 - Tuning and Recording Robustness
  • 02 - Stability
  • 02 - Fixed incorrect blue background
  • 02 - Fixed R icon not displaying in Folder during recording of a event in Folder
  • 02 - Fixed unable to Clear Delete Marks in Folders in Mark And Delete Screen
  • 02 - Fixed unable to modify extension on single episode of a booked series
  • 02 - Fixed modifying extension of already booked series does not update episodes already in ToDo
  • 02 - Fixed black screen shown when blackout is removed
  • 02 - Fixed no Kepp or Delete On Screen Display OSD after FF4 to end, RW, Pause, then Advanced
  • 02 - Tuning Robustness
  • 02 - MediaShare – Fixed unable to play slideshow in PIG when browsing thumbnail
  • 02 - MediaShare – Fixed wrong song ordering
  • 02 - MediaShare – Fixed blank thumbnails
  • 02 - MediaShare – Fixed FF of pictures jumps back instead
  • 02 - MediaShare - Stability
  • 03 - Fixed channel banner program information being incorrect after using previous button
  • 03 - Stability improvements, including issue after deleting in response to K/D OSD.
  • 03 - Fixed recently searched keyword not saved in previous screen
  • 04 – Fixed stuck boot 1 of 2
  • 04 – Recurring manual records no longer share playlist folder
  • 04 – Faster deleting large folder from playlist
  • 04 – Improved history for manual records
  • 04 – Stability improvements
  • 04 – Fixed DIRECTV On Demand results list
  • 04 – Fixed issue where KEEP ICON is missing after using mark&delete
  • 04 – Fixed mini-guide with guide tip
  • 04 – Lipsync improvement
  • 04 – Media Share Stability
  • 05 - Added ability to send a Diagnostics Report back to DIRECTV
    See notes
  • 05 - Added New Release category for DIRECTV on Demand homepage
Updated
  • 01 - History messages for recording and deletion events
  • 01 - Close Captioning Left Placement
  • 05 - PC Mediashare is back
  • 05 - Faster category search and sort
  • 05 - Faster loading DIRECTV on Demand listing
  • 05 - Program Info Screen text
  • 05 - Stability
New features
  • 01 - Triple Tap support
    e.g. title/name/keyword search screens, favorite list naming, etc
  • 01 - Search for PPV Movies in guide options panel
  • 02 - 1-touch record hint for program cells/items
  • 02 - Add "Move to Top" hint OSD in the Prioritizer screen
  • 02 - Add a display settings option in the System Setup screen for the enabling/disabling of the 1-touch Record Tip OSD
  • 03 - Daily Fortune
Notes
  • 01 - This CE cycle is expected to contain new features
  • 04 – THIS DOWNLOAD WILL REMOVE GUIDE CACHE AND THE GUIDE ACQUISITION WILL TAKE LONGER
  • 04 – BOOT STUCK WARNING: If you could not boot with the last CE with network attached, and had to revert to national to be able to boot with network, do not try POKEEYENOW. If you try it, your HR20 will probably still hang/crash on boot. If you insist, then you will have to boot without your network and POKEEYELATER to correct.
  • 05 - Send Diagnostics Report:
    requires IAMANEDGECUTTER keyword search to be enabled
  1. Use the Menu+Info keys to get to the Misc Options screen
  2. Select the Report option
  3. Click on Send
  4. Wait for it to finish
  5. You will receive a confirmation key in your response.
    *** Please include this key in any post you make in the issues thread ***
  6. Please note that you can only send one report per 24 hours
Thanks... I still dont get this fortune cookie thing.
From my posts last week - hopefully answers it:
The easter egg will let you access a network services menu and manually configure your ports instead of the receiver using UPnP with your router. The second thing, it adds a daily fortune to your menu, similar to those in fortune cookies. The first part being a good add-in that some may need, the swcond part is unnecessary, and hopefully didn't take long to code.
The network services would let you assign ports for the upcoming media-share software that will allow you to view programs on a computer. It is just starting beta-testing right now.
This way, you can configure ports if you do not use UPnP.
Just finsished downloading here too, I'm rebooting now. That explains why I havent gotten the fortune cookies yet.. I didnt download last weeks because I was asking questions to charlie, and wasnt home. :)
Well, not that Don had "no brick" - I'm in.
Really I was just watching a ball game first, but hey.
HR20-100 CE Release 5/23
HR20-100 CE Release w/e 5-2
