SuperDish Mast/Pole??? | SatelliteGuys.US
cyrusdss
4
I got a SuperDish that I'm trying to install on my balcony. I don't have the mast for it. I want to use a fence type pole instead. From what I read, I need a pole with a 2" outside diameter. I looked in Lowes and Home Depot but couldn't find anything that size. They were either too small or too big.
Where do you think I can find a regular pole with a 2" outside diameter. I'm in Newark, CA, 94560. Thanks.
I got a mast pipe for ground use when I installed the Super, now gone, from a local Dish Network retailer. He just gave it to me even though he was still installing Supers at the time. I'll bet now there are a lot of shops with surplus pipes laying around.
2" O.D. is indeed an odd pipe size. Galvanized chain link posts, the one I used was called a dock post, are 1-5/8" O.D. and are just fine for 300/500/1000 series dishes. The Supers were the only ones to use the 2" pipe and to mount a new 1000.2 I had to adapt a small section of fence post to the old Super's post. You might be able to do something similar or sleeve a smaller diameter post.
sigmtr
sigmtr
2" is not an odd size it is the size they use for conner posts. THe 1 5/8" is the line posts. It also does not have to be exactly 2" post if you find something that is a bit larger it will still work. Some heavy pipe like black pipe will be close, but it's not cheap.
60 bucks for HD locals dish!!
?? Which Way To Tweak ??
