Not sure if this is the right place to post a question. Can I receive Dish NW in Canada and up into Alaska with the 500 Pro dish?
The 500 is an 18" Dish that has an LNB to hit 2 satellites (119 & 110) at the same time. Based on your information, the OP would NOT be able to use the 500 Dish.I'm not sure what the 500 Pro dish is, but I live in Anchorage and you'll need around a 30 inch dish to receive 119 which contains most of Dish programming. In order to receive any HD you'll need at least a 4 foot dish pointing at 110.
Although the 4 footer would be additional cost in Anchorage, the basic install to get 119 is free.
Geoff
Actually a DISH 500 is a 20" dish designed to pick up 110 & 119 in the continental US. Pro or Legacy would refer to the LNBs mounted on the DISH 500 dish.The 500 is an 18" Dish that has an LNB to hit 2 satellites (119 & 110) at the same time. Based on your information, the OP would NOT be able to use the 500 Dish.
Geoff
Echostar 11 should fix the signal issue in AK with 110w.
Since we're on the subject, what's up for Alaska and HD? The "Ak package" on 110 pretty much sucks for content and there's only like 10 channels. We also seem to have no hope for HD networks. I am stuck with crummy All American Direct. Also you guys were talking about 148. I hadn't heard of hitting 148 in AK for anything. What's on it? I am in Southeast, north of Juneau.
148 has digital locals (HD) on it for Fairbanks & Juneau
Not to get even more of topic, but does Fairbanks or Juneau even do HD? I thought they only did upconverted SD, due to being one extra hour behind and receiving the network feed. I do believe the stations in anchorage like KTUU can do HD.
Not sure about Fairbanks,
Like a few others mentioned, I looked on dishchannelchart, and "digital locals" for Juneau are listed on 148, but they are not HD. What's the point, isn't everything digital on satellite? I can already get Juneau on 110, although as Chena pointed out, the quality is something that even Fred Flintstone wouldn't watch!
I wonder if the source is bad, the two Anchorage HD channels that Dish carries are fine. Although I would like them to start carrying the complete lineup.
Limited time offer
