AMC3 bird companion? | SatelliteGuys.US
magnigyro
326
2
Bird AMC3 in 87W is alone in his large dish...Someone can recommend a bird to place next to AMC3 and share same dish?
Thanks...
you mean another LNB?
You could try 91 or 93...both have feeds on it
Yeah, that´s I mean....looking in "the list!" I would like Galaxy 26 at 93W, has very interesting channels...University, Wright Patterson, Macys, Flower show...
OK, guess new lnb must be right side and little bit lower...:rolleyes:
I´ll try the strongest tp marked there...I am so excited!:luvlove:
Thanks!:hatsoff:
also tons of news feeds that come and go :)
if you are standing in front of the dish facing it, then yes it would be to the right. When using multiple LNB's they go backwards from how they are in the sky :)
11710 V 14320 is the strongest usually.
CNX Trio Lat. Long. Settings
Clear HD channels
