HR20-ALL CE Release 4/4 & 4/5 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE / Version
HR20-700 {CE:12:08}
HR20-100 {CE:12:08}
Window of opportunity to download:
Friday, April 4, 2008 11PM - 2:30AM ET
Saturday, April 5, 2008 11PM - 2:30AM ET
PLEASE READ THIS FIRST! CE DOWNLOAD WARNINGS / AGREEMENT
PLEASE READ THIS SECOND! CE DOWNLOAD INSTRUCTIONS
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
CHANGES FROM THIS RELEASE:
  • 08 - Improvements to GameSearch
  • 08 - Stability
  • 08 - Miscellaneous UI
  • 08 - MediaShare
  • 08 - Boolean keyword search removed - check recordings if you used this feature.
  • 08 - Guide is not cached from previous version
CHANGES FROM PREVIOUS RELEASES:
  • 01 - LiveTV audio issues after stopping mediashare and no audio during slideshow
  • 01 - Fast forward to true live TV viewing
  • 01 - History status for VOD downloads
  • 01 - Improved audio
  • 01 - Stability
  • 01 - GameSearch to automatically find same game on other channel if currently tuned game is blacked out and showing OSD x (This is a very cool feature...)
  • 01 - Keyword search on channel or channel range and title only or name only (Geek dream feature)
  • 02 - Will reply to a network PING request
  • 02 - Channel Banner updating immediately
  • 02 - Fixed ScreenSaver with MediaShare Video Playback
  • 02 - Improved Parental Controls
  • 03 - System boot up improvement
  • 03 - Video output improvement
  • 03 - Stability
  • 04 - Improved ability to watch recorded content/when signal not present during startup
  • 04 - Media Share: Start a new playlist while another playlist is in playback mode
  • 04 - Media Share: Start/Stop DLNA Videos enhanced
  • 04 - Media Share: Improved handling of multiple units on the same network
  • 04 - Misc. Issues
  • 04 - LEFT (or BACK) to Search Screen (from sort screen) doesn't clear out search string
  • 04 - Media Share - UI Polishing
  • 04 - Other UI Polishing
  • 04 - Additional program details (First Air Date, Actors, ect)
  • 05 - Autorecords with Boolean Search logical operators appear in TODO list
  • 05 - Channel up and down updates the selected item in the Prioritizer
  • 05 - Playlist new displays the recording date
  • 05 - 1xFF performance and appearance
  • 05 - Guide scrolling performance
  • 05 - GameSearch avoids partial recordings while searching for games
  • 05 - Stability improvements
  • 06 - Detection of second tuner
  • 06 - UI polishing/fixes
  • 06 - DIRECTV Mediashare (many)
  • 06 - Stability
  • 06 - Increase to the number of actors presented in the INFO
  • 06 - Audio (robustness against dropouts on certain setups)
    [*] 07 - Stability
    [*]07 - Media Share Improvements
Earl, over at Dbstalk, describes this C/E this way:
Most a maintenance fix, with the Boolean Search features removed.
So, if you use the Boolean search feature, better pass on this one....
No new features.
Notes added above.
As moonman mentioned - the boolean search features are being removed (no idea why at this point).
If you use those features, you may want to reconsider downloading tonight, or plan to resetup any recordings that used it.
I use the boolean frequently so I'll pass. I wonder why they are removing it? Could it be to implement something easier to work with?
I noticed yesterday that when I pause a program (live or recorded) and resume play, the volume is about 1/2 the previous volume as before pausing for about 1-2 seconds, then it returns to "normal" levels. Is this a known issue, or is this just on my end? Is this what is referred to as "06 - Audio (robustness against dropouts on certain setups)" or is that something else entirely? This seems to be happening on OTA and Sat channels, SD and HD programming alike.
For the record, I was very up-to-date on CE releases on my two HR20-700's until about 2-3 months ago and just haven't been home (or awake) when the CE releases were pumped out. So I came into this CE from the National Release.
I have been playing with my FF / Rew features during the race and found NO ISSUES with volume.
Jimbo
My audio is via TOSLink...do those go bad? I don't have a spare cable lying around...you think I should I even consider picking up a new one?
That would be rare unless you did something to the cable.
You could roll back to the national release and see if the problem goes away - that would clarify if it is the CE.
Special Tues. night C/E
HR21-ALL CE Release 4/4 & 4/5
