at least it was remote and not ird, consider yourself lucky i guess
although that sucks
That sucks.
Do you have a harmony remote or similar? I thought that they used to have the Pansats, viewsats, and coolsat STB's in their database.
stogie was that thing stepped on??????
or broke in shipping??
I'm sure somebody has remote for sale for it, might be pricey.
My ebay days are over, I think I had exactly .500 getting- robbed average, so I quit while I still had a decent losing percentage!
actually, I think the 8000 was nice in the fact it did not respond to other units remotes. I think iceberg mentioned it in a review that it was a nice feature that his 5000 and 8000 remotes didn't interfere.
Search method - If Your DEVICE Does Not Respond.
Step 1. Turn on your DEVICE.
Step 2. Press OK Key and press DEVICE Key in 2 seconds at the same time.
LAMP LED will blink twice
Step 3. Press CH+ or CH- key until DEVICE turns off,one and one.
LAMP LED will blink
If the CH+ or CH- key is not pressed in the course of 10 seconds, this function is canceled.
If your DEVICE is turn off
Step 4. Press OK key
LED will blink Twice
Please use this method if none of the Set-Up Code numbers worked for your device during the three digit
code method or if the manufacturer or brand for your device if not listed in Set-Up Code Tables.
so let me get this stright..the person that sold you this unit on ebay sold it with pre-flashed hacked software? Im assuming for DN and BEV?? If so, this person had a huge set to sell that online...
Once you've exhausted all other solutions, shoot more pictures, and if I think I can fix it, I'll tell ya.
Would be happy to give it a shot, no strings at all.
Just wouldn't want you counting on 100% success, without a backup plan.
Looks encouraging, but hard to tell from only those two shots.
If my coolsat 5000 remote works for it, I will let you borrow it. Do not use anyways, just need it for resale...
Yea...my ebay record as of late hasnt been that good either...i think im .500 too for the last 6 orders...
you might be able to program your coolsat 5k remote to function as STB or VCR
should be able to follow the programming section in the manual
can't remember what the default code was maybe 000 or 008
or scan for the code
just a thought
Limited time offer
