is there any way to combine the original hard drive and a new hard drive in an enclosure and keep the recordings on the original drive?
Nope.
I did a lot of reading on multiple forums trying to find an eSATA for my HR21 DVR. I hooked up a Cavalry CADA002SA2-H 7200RPM 2TB USB 2.0/eSATA External Hard Drive $505.68 from Amazon.
It was simply plug & play. Turned on the HD first then plugged in the HR21 and it recognized it right away. Have been recording HD like crazy for the last month with no trouble. Have over 35hrs. of HD with 82% available space.
Try to use Seagate utility and disable sleep mode or power saving mode.
I would play with settings while the EHD connecting to PC. If it will do long delay to response to click on right button of mouse ( after a few minutes inactivity), then I would definitely disable power safe mode.
The drive can't install anything into DVR, as 1) the host is DVR 2) only host can do that 3) DVR by design will not install anything from EHD 4) DVR have different CPU/OS and can't install PC [Intel] programs from EHD 5) etc.
Limited time offer
