I guess I was trying to avoid the watching at a low dim picture level for a few days. I wont actually get sat signal until Thu, so i guess Ill just leave it on 24/7 for 100 hours.
I agree. I do believe this is still a debatable issue with plasmas. I have read 100 break in period as well as nothing but watching the tv.
I chose the ladder.![]()
Yeah, I was thinking that the espn ticker would be bad.
Put the picture mode on zoom and let it run. That way it will get rid of any static channel logos.
S~
Will do, going to pick it up tomorrow, then Dish should be out Sunday for installation.
Do you know if I can just use a snowy channel to run continously for break in?
Evangelos Angelides - HomeI downloaded a break-in DVD from avsforum but for the life of me can't find it there now.
I have the 50pz700u and love it (chose it over the 5080 which was $600 more)... sounds like you made a good choice.
I'd advise people to be careful of "breaking in" yer plasmas. Yes you should be careful for the first 100 hours, but putting on a DVD or TV station unattended for hours on end is kinda risky if you think about it... DVD player locks, station freezes.... then your preventative measures have ruined your TV. I do remember reading a couple people on AVS having this happen to them... I just say watch TV as normal but be careful to not watch too much letterboxed/pillarboxed/ticker/logo stuff for the first month or so.
One of the tv calibrators on AVS recommended the same thing, just set your pic settings and avoid stationary on screen items. Im going to try the break in dvd.
I use the break-in dvd more for reactive measures than proactive measures. If I've watched a letterboxed DVD or Blu-Ray I will let the break-in DVD run for about 1/2 hour after. This takes care of any residual IR.
Limited time offer
