What signals can you "see" at 61.5? | Page 8 | SatelliteGuys.US
I've had CHANGES!!!!
All, have new changes to xpndr readings @ 61.5
Also all receivers have updated software: My 311's now have P431 (new signal meter #'s that match my 622) and my 622 is up to L449
xpndr changes:
01 23% (wrong sat, 110) see note below
06 61% name not aq'rd
07 37% name not aq'rd
15 36% name not aq'rd
28 38% name not aq'rd
All the above showed no lock 1 week ago. I did the foil trick on 110 & 119 and maintained the signals, moved the foil to my 61.5 dish & they went away.... Hmmmm
Rob
How many time I should post spectrogram and Mike/rocatman links to a status of the sats/tpns ?
AGAIN: tp4, 6, 26, 28 are DEAD ! Forget about the tpns' measures. They are meaningless.
Yup, confirmed. TP1 is now reporting correct transponder information, and the miami local HD channels are gone. Only null packets now.
Spotbeam signal much lower than conus TPs.
PAT Version Number: 0
Transport Stream ID: 1501 (0x05dd)
NIT: 61.5W 12.224 GHz RHCP 21500 2/3 8PSK (DVB-DSNG/Turbo/DVB-S2), DVB-S
PMT PID 16 (0x0010) - Network
PMT PID 32 (0x0020) - Program 5150
PMT PID 32 (0x0020) - Program 5151
PMT PID 32 (0x0020) - Program 5152
PMT PID 32 (0x0020) - Program 5153
Those channels aren't even in the main tables yet :)
TP 7,9,13,15 disappeared here in the east.
Edit: Added spectrums from 61.5 and 129 for comparisions.
Here are the latest BLSA scans for Echostar 61.5 from San Jose, CA.
I previously had no signal on Transponders 1, 3, 4, 6, 7, 15, 26, and 28. Now, Transponders 9 and 13 have no signals also.
Now receiving spotbeam signal on tp 1, locked echostar 61.5 west. Strength is 82. Eastern NC
TP 15 now reports Locked 61.5 with Spotbeam, strength 77.
It is the only one that reports spotbeam now.
Here in northern Indiana, I see SpotBeam 01 at 9-10, which doesn't allow my 211 to lock in. 15 is still a no-show here.
Here we go guys... TP 5 and 11 just dropped here and the uplink report reflects the change to beam.
Can anyone verify on the east coast?
625 in northern VA. I am now reading "spotbeam" on transponders 1, 3, 5, 9, 11, and 13. Tp 13 gives the highest signal strength I've ever seen: 94 on the new scale. It also behaves anomalously. 1st it says locked - (blank) with "spotbeam" where "transponder" was. Then it says name not acquired. Finally the "spotbeam" goes back to "transponder". Hmmm. Maybe they're changing things as I type this?
Edit: Still 0 on transponders 7 and 15. I see some folks (west of here?) are seeing 15.
01 - 79 Locked NNA
03 - 50 Locked NNA
05 - 81 Locked NNA
07 - 82 Locked NNA
09 - 0
11 - 0
13 - 75 Locked NNA
15 - 74 Locked 61.5w
Only 2 TPs have dropped out in N. TX so far. But, signal strength has gone way up on 1,5,7,13,15.
this is getting exciting, I live in eastern VA & i'll have to see what i have tonight & compare to you!
Anyone get better than low 30's signal on 61.5
I lost two HD channels in Puerto Rico
