How to get rid of hacked FW on Coolsat 8000? | Page 2 | SatelliteGuys.US
Unfortunatly the box is out of production, so it looks like going used or on ebay is the only way to get one.
They do have a new version, the 8100, but the information on it does not provide any insight as to whether it does DVB-S2. Then again, there was no information the 8000 did either.
The CS8100HD includes a USB port and PVR capabilities. The other specs are identical to the CS8000HD. My understanding is that Coolsat wanted to be the first to market a HD FTA receiver so the CS8000 was released without the USB functionality. I saw on another site there is also a newer factory bin (11192A), however, I didn't see that listed on the Coolsat web site. There may be some fixes/updates on that bin as well. They did update the motor controls and switch support in the 11176A bin which I was quite happy about. Has anyone tried the 11192A bin yet?
choices
...I wonder if it can be updated through firmware...
Okay, I'm building them and I have two choices:
1). provide free firmware update to the existing boxes in the field.
2). sell a new box, which may be identical inside, using the new firmware.
In some cases, these "manufacturers" as we think of them, just contract with a factory in Korea or China, to make the boxes.
How much actual engineering some companies put into the process varies a lot.
It may be no more than a shopping list of features.
From what I see, the reason the new family of Coolsats are incompatible with the old ones, is that they have a new factory building them.
What does that tell you about Coolsats engineering input?
Sounds like mostly a Marketing-driven company.
Not to pick on just them, the Visionsat comes from the same factory as another similar box, just with a few feature differences.
And I'm happy with both, so these companies are doing something right. ;)
Yes it is true that they are using a new factory for the latest Coolsat FTA receivers. This may be an issue with clone boxes that were finding their way into the market. I read also on Coolsat's website that they are no longer offering warranty on receivers sold after October 2007 (CS6000), again I believe due to the problems with clone boxes. All the new receivers in the CS-x100 line are from the new factory, as well as the CS7000 PVR and CS8000 HD.
Note: The latest factory software for the CS8000 is 11169A or 11170A depending on which version of the site you go to (Canada/USA).
I think it is mostly in the initial setup, like auto detect for satellites, which isn't much use for me since I use a motorized dish. It also has the beep on scan for the signal and some other minor changes, but it seems to cause problems for EPG so I reverted back to the earlier version. There was some minor issues with manual motor control (not displaying east/west) and DiSEqC selection that was fixed in later versions, again not really a big issue using USALS. Have you ever had much luck getting any FTA manufacturers/importers to update/bug fix/add features (like blindscan) for the official factory software?
Visionsat IV200 Hard Drives
need motor info - just got P* 1 M dish
